Two questions about keeping it in the footprint
I'm wondering what thoughts people may have on these two rules.
Is it allowed to exceed the footprint in the process of assuming the PC? What I'm imagining is a robot that begins with a component hanging parallel to the body of the robot in SC. In PC, that component rests perpendicular to the body of the robot. In both SC and PC, the component is within the footprint, but in order to get from SC to PC it (momentarily) must swing outside the footprint. Is this allowed? Or are we to read this rule as simply allowing multiple playing configurations for the robot without any sort of special allowance for the space spent changing from SC to PC. Quote:
My reading of the rulebook supports the conclusion that a robot may never extend outside the 28x38x60 footprint, which may (but not must) be the same as its bumper zone. As a way of understanding this, you could have a 28x28 robot that reached out to 36 inches, because that would be within the footprint, even though it extended beyond the bumper zones. Last edited by Petey : 05-01-2009 at 10:42. |
Re: Two questions about keeping it in the footprint
Also, it must not ever extend outside of the 28x38x60 box, as at any time during the MATCH, the ROBOT is decidedly in some PLAYING CONFIGURATION. A ROBOT can have many PLAYING CONFIGURATIONs, but no one of them can extend beyond the 28x38x60 boundary. Essentially, if you want an arm type manipulator, you need to build your STARTING CONFIGURATION (and by extension, your drive base) to be substantially less than 28x38x60. |
edited Quote:
I know what you're saying about the wording implying some sort of transitive state, but as I said in a different thread yesterday, the GDC typically answers Q&A questions inline with the INTENT of the rule, and the INTENT of this one was to restrict us to the 28x38x60 box.
Petey, I would ask it on the Q & A Forum. |
1075 guy is probably right, but I may ask this in Q&A.
And I assume I'm right w/r/t the second question about bumper zones and footprints correct? |
R11 states
Maximum Width: 28 inches Maximum Depth: 38 inches Maximum Height: 60 inches Maximum Weight: 120 pounds While width and depth are basically interchangeable based on how one views the robot, height is referencing the distance from the bottom of the robot to the top of it with a height of zero being at the surface which contacts the ground. Therefore, "flop bots" are illegal if they plan to tip over from a height of 60 inches and then afterwards have a width or depth of that dimension. Along with that, it seems pretty clear that you cannot build a robot with a 38 inch height so your 60 inch dimension could be saved to extend an arm or something. The rule seems pretty clear to me that your switch from starting configuration to playing configuration would violate the rule because the change would occur during the match. |
Thanks! "During" seems to clear up my question about the transition betwen SC and PC.
| Questions about the engines. | yuval_bertocchi | Rules/Strategy | 1 | 24-01-2007 11:42 |
| Two questions about webdesign | Adam Y. | Website Design/Showcase | 7 | 23-05-2005 22:13 |
| Some questions about the Toronto regional | DivideByZero | Regional Competitions | 4 | 20-03-2005 19:03 |
| questions about the servos | Alex Golec | Motors | 1 | 23-01-2005 20:05 |
