Go to Post Don't criticize them for what they have, learn from what they do. - xSAWxBLADEx [more]
Unread 05-01-2009, 17:18
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Rookie Year: 2007
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
can we control the amount of air to control the speed of the cylinder?
any suggestion or answers are highly welcomed.....thank you
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 05-01-2009, 17:31
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: can we control the amount of air to control the speed of the cylinder?
Well technically you can't control the speed, but you can control the acceleration which gives you a little control over the speed. Here are some things my team discovered last year. By placing a needle valve (they have a small screw and locking ring and come in the KOP) on the venting end of the cylinder it will slow the cylinders extension based upon how fully closed it is.
If you want a cylinder to extend faster you must dump more air into by using multiple valves etc (see 39 last year).
Changing cylinder speed during a match would be more difficult, but is definitely possible.
Unread 05-01-2009, 17:32
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
In the past, my team has used 3 valves to control the speed of a piston. The first valve was a on/off valve to change the direction of the piston, and the other two valves had flow limiting exhausts on them. You send the output air from the first valve and then "T" it to the other two valves giving you the cases: both off, one venting, or two venting. This can give you a custom slow and fast speed for your piston, and if you wanted to you could add a number of valves to get a finer resolution, given that you can get each one to limit the air flow that much.
Unread 05-01-2009, 17:34
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Rookie Year: 2007
Thank you.. and one more question, can we use three different regulators to the same cylinder?
2008 LA Regional
2011 Bound for same
KQ6Y
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Yes. There are commercially available, 125 PSI rated flow-control fittings that can go into a cylinder. They aren't in the KOP this year, though.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 05-01-2009, 17:36
Rookie Year: 2007
Oops My apologies,
I stated the valves were in the KoP, but I believe Eric is correct--this year they are not.
Unread 05-01-2009, 17:47
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Merle,
There are needle valves that are available that can control the volume of air that enters/leaves the cylinder. However, they are not designed to control the speed at which a cylinder operates. Teams have experimented with lower working pressures by adding a second pressure regulator downstream from the 60 PSI working regulator as described in the pneumatics manual. Please be advised that the valves do not seal much below 30PSI and so they become unreliable at reduced pressure.
There are many threads here that discuss this problem for the price of a search. The discussions will give you an insight to some of the team experience from past years.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 06-01-2009, 16:04
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
This brings me to ask the question...
Why do we have so many less pneumatic components in the KOP this year??
We don't have any of the hose connectors and flow regulators we have always had in the past. We also only have one solenoid. In the past we had several.
We still have the compressor and its associated fittings and gauges and such but we don't have the final fittings to move the air around.
I wonder if FIRST lost that supplier ??
We really enjoy using pneumatics and they are easy for rookie teams to put together... or at least they USED to be easy... now they will have to purchase their own components to handle this.
I DID see that we can use cylinders that are NOT Bimba this year.
They just have to comform to the size/length requirements...
Interesting...
I have fittings left over from other years so I can proceed...
We should all support rookie teams by sharing these older fittings and information with them... Perhaps we should start a clearing house for the
pneumatically disadvantaged (IE Rookie Teams) and donate some of the fittings they will need (and old solenoids that were never used...)
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 13-01-2009, 22:50
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
The ultimate solution would be to purchase an analog output card for the cRIO. Though I dunno if it would be legal.
Purchase a 9263 4-channel analog output 0-10V output module to control a pneumatic analog regulator.
Next you'll need a 12VDC version of an analog regulator.
Last you'll need an external piloted valve because most KOP valves are internal pilot and won't trip the spool below 30PSI if you want to control PSI down to 1 PSI use an external pilot valve and vary the regulator with an analog 0-10V control signal with a full scale of 60 PSI is equal to 10volts.
You'll have to post some questions to make sure all the above is legal though...
Attached is a spec sheet on something I was checking into.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 13-01-2009, 23:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
There's another, option that's quite likely to be legal, though it's largely insane. You could get a standard 12V, high frequency, low response time solenoid valve and wire it to the pneumatics bumper just like you would any other valve. Then laugh maniacally while telling your programming team that you want to duty-cycle control your solenoid valve. It's marginally nutty, as it hasn't been done in FRC before, but I think it'd work fairly brilliantly if you got a valve with a good enough response time and maximum operating frequency. Festo makes some rather fast valves, but they're 24VDC operated. Still, I think it'd be interesting if someone tried this in FRC.
Unread 13-01-2009, 23:57
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
I think the reason is because we can't extend outside of our starting area, so any pneumatics are going to be extremely limited in length, and usage. our team on day three just decided that we couldn't think of a way that we could use pneumatics in a better way than we could use a motor or a servo, it would just have been a waste of space to put that stuff on there for one or two small pistons that would need tons of equipment to use (compressor, air tanks, hose) compared to 2 wires per motor, and a spike.
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 14-01-2009, 13:13
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
1075 in the past has built a multi-position pneumatic arm. To control the speed of your pneumatics, teams typically use the flow control fittings that came in the kit (at least in previous years). To build our multiposition arm, we have 3 valves, 1 to control direction, and 2 to control the flow of air to and from the direction valve. by switching the source and exhaust lines, you can make the piston stop at any point along its travel.
Unread 15-01-2009, 10:47
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Rookie Year: 2007
Multi position would work. Do you have a scematic of what you described?
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 11-02-2009, 03:47
Integral Integral is offline
AKA: Ross
FRC #1130 (Robo Rebels)
Integral is an unknown quantity at this point
We are using the Festo to switch between a high and low pressure. Seems to be working pretty well. The hard part was writing a latch circiut in Labview to lock the Festo in the powered position. We also found that we had to have the high pressure in the correct port, to provide the internal pilot pressure.
  #15   Spotlight this post!
Unread 11-02-2009, 13:55
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
I'm guessing that either SMC isn't sponsoring FRC as much this year, or the pneumatic fittings were eliminated as a cost-saving measure. Push-to-connect fittings cost anywhere from about $2-$10 each for 1/4" OD tubing and either 1/8" or 1/4" NPT thread. So that entire bag of fittings from previous years cost around $150-$200 dollars.
However, I'm really concerned about rookie teams not knowing these connectors exist and not using pneumatics because they don't know how to connect them. If this continues, existing FRC teams probably have enough of these fittings to last two or three years, but after that most teams will have run out of them. I certainly hope these are included in future years and in rookie team KoP.
In case anyone was wondering where to get more of these, you can buy more push to connect fittings at MSC Direct or McMaster. If you are looking on McMaster, search for "push-to-connect" (without quotes), then select the type of fitting, then select "For Use with Air", then select "For Use with Polyurethane tubing".
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Changes in the New Revision of the Control System Manual mcf747 General Forum 2 07-12-2008 22:10
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
Can we use foot pedals on the ground to control our robot? Ericgehrken Rules/Strategy 3 19-01-2007 21:48
Can We Use A N64 Controller To Control The Robot pobots Electrical 25 18-04-2003 12:48
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
