Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. - Billfred [more]
  #16   Spotlight this post!
Unread 11-02-2009, 07:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: can we control the amount of air to control the speed of the cylinder?
Originally Posted by ZInventor View Post
I've worked with the SMC solenoids (that used to be in the kit) for a coupple of years, and was able to run them very reliably at pressures down to 5 psi, which we used last year in competition (frcteam2002)
this year, we're running an SMC at 20psi, and have not had any problems yet...
-Z
Just so you remember this when and if you have problems.
Al
WB9UVJ
www.wildstang.org
________________________
  #17   Spotlight this post!
Unread 11-02-2009, 07:54
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Here's a question on a related note:
We will only have a working pressure of 45 psi for the entire system as well, which we know how to implement. However we would also like to slow the air flow down to the entire pneumatics system (passed the 45 psi regulator) on our robot. We also need all four of the pistons on our linkage drive train to kick in/out at the same speeds (this is more important than anything).
How would we achieve a lower flow rate without putting independent flow control valves on the pistons themselves? I'm sure there's a flow rate regulator somewhere, but everything I look at is somewhat confusing, and somewhat expensive. If we can do this we would be able to fully automate all four independent linkages without running out of air in a 2:15 match .
GitHub
  #18   Spotlight this post!
Unread 11-02-2009, 10:05
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Rookie Year: 2007
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
Sounds like you need a series of reduction regulators to each distinct cylinder. The balancing act is the hardest. Maybe make a test pressure dongle to a T and check each leg, then tune it up.
We learned more about pneumatics in 5 weeks than we ever knew. Our robot works with one speed going up and a different speed going down.
Thanks to everyone for their info
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
  #19   Spotlight this post!
Unread 11-02-2009, 13:21
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Look at the SMC in-line speed controllers on this catalog page.
  #20   Spotlight this post!
Unread 11-02-2009, 13:39
JesseK's Avatar
FRC #1885 (ILITE)
Ah, I see. So we already had the answer staring us in the face, yet we assumed you had to put the elbow flow control valves directly on the piston ... silly us . I'll look tomorrow and see if the ones we already have fit the brass t-junctions. Thanks a ton!
GitHub
  #21   Spotlight this post!
Unread 11-02-2009, 13:55
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Originally Posted by Bob Steele View Post
This brings me to ask the question...
Why do we have so many less pneumatic components in the KOP this year?
I'm guessing that either SMC isn't sponsoring FRC as much this year, or the pneumatic fittings were eliminated as a cost-saving measure. Push-to-connect fittings cost anywhere from about $2-$10 each for 1/4" OD tubing and either 1/8" or 1/4" NPT thread. So that entire bag of fittings from previous years cost around $150-$200 dollars.
However, I'm really concerned about rookie teams not knowing these connectors exist and not using pneumatics because they don't know how to connect them. If this continues, existing FRC teams probably have enough of these fittings to last two or three years, but after that most teams will have run out of them. I certainly hope these are included in future years and in rookie team KoP.
In case anyone was wondering where to get more of these, you can buy more push to connect fittings at MSC Direct or McMaster. If you are looking on McMaster, search for "push-to-connect" (without quotes), then select the type of fitting, then select "For Use with Air", then select "For Use with Polyurethane tubing".
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
  #22   Spotlight this post!
Unread 11-02-2009, 14:05
Just Itinerant
...yet we assumed you had to put the elbow flow control valves directly on the piston ...
All the world's a piston...
  #23   Spotlight this post!
Unread 11-02-2009, 15:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I wonder if you couldn't use one of the flow control valves with a servo...
Changes in the New Revision of the Control System Manual mcf747 General Forum 2 07-12-2008 22:10
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
Can we use foot pedals on the ground to control our robot? Ericgehrken Rules/Strategy 3 19-01-2007 21:48
Can We Use A N64 Controller To Control The Robot pobots Electrical 25 18-04-2003 12:48
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
