Go to Post ...your education can be interesting and even fun. If you look a little farther down the path, you WILL "use this crap", and "this crap" can even be cool if you know how to use it. - Chris Hibner [more]
Unread 05-01-2009, 18:42
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Question Tank Drive
Ok, so I have found the basic code for tank drive, however we are looking for a way to implement that with the basic robot main code. when we copy paste it into the main we get a red box around the case structure containing the arcade drive....
Help?
Unread 05-01-2009, 18:50
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
Re: Tank Drive
in the basic robot main vi just right click on the existing arcade drive icon and go down to replace and select under robot drive tank drive. that should change your style to tank drive after you upload the code.
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
belt drive/tank treads dradius Kit & Additional Hardware 14 19-06-2005 23:16
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
