Terminal creation.
We just made a sub-vi and we need to connect the icon into the program, but there are no terminals on the icon. How do you create the terminals? If it helps, we want an interger to be inputed and a cluster to be outputed.
Re: Terminal creation.
On the front panel window, right click the icon and hit Show Connector.
Play around with adding and deleting connectors and patterns. To set a connector, click the connector in the icon to select it, then click on your input on the front panel. The connector will change color to the type of connection. That's the basics of it. =) EDIT: Attached are 2 pictures. Last edited by whitetiger0990 : 06-01-2009 at 00:53. |
You can also do fancy stuff like changing the pattern and such.
You can also design the icon so that they are not completely rectangular and do fun stuff like those mathematical operators |
Thanks for the help guys we got it.
| pic: Our creation | hiimcristhian | Extra Discussion | 12 | 27-08-2007 14:22 |
| New team Creation?? | skibumm101 | FIRST Tech Challenge | 6 | 07-06-2006 21:03 |
| #define creation | NASAbound1636 | Programming | 3 | 02-02-2006 23:40 |
| Robot Creation Help | GregTheGreat | Technical Discussion | 5 | 23-10-2003 12:09 |
| dean creation | archiver | 2001 | 2 | 23-06-2002 22:47 |
