Go to Post It's like the people from Pimp my Pit came and had it professionally done. - [more]
View Poll Results: Rear wheel drive vs. Front wheel drive vs. All wheel drive
All wheel drive 110 88.71%
Rear wheel drive 7 5.65%
Front wheel drive 7 5.65%
Voters: 124. You may not vote on this poll
Unread 05-01-2009, 23:10
eNyoron eNyoron is offline
Captain, Programmer, Clueless.
FRC #1787 (untitled.txt (as of now))
Team Role: Leadership
eNyoron is an unknown quantity at this point
Send a message via AIM to eNyoron
Re: 4 wheel drive vs. 2 wheel drive
Between rear and front wheel drive, it's really not viable to use a rear wheel drive unless you don't plan on ever exchanging an empty cell... or being pushed into a corner. That portion is carpeted and if you use rear wheel drive to get there, you're going to end up with the front wheels on the carpet with high traction and the powered wheels on the regalith with low traction, making it incredibly difficult to move. And backing into the corner wouldn't work either, there's a trailer in the way.
Unread 06-01-2009, 07:20
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
Rookie Year: 2007
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
Where your weight goes is up to you but please know that any and every wheel touching the ground needs to be powered! Also know that your bot should weigh 119.99999 lbs (without battery and bumpers).
Unread 06-01-2009, 07:49
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
My recommendation would be to run some tests with the kit chassis. We subbed some wheels out on a 4x4 chassis last night and ran it on the FRP and carpet. We did a long wheel-base and a short wheel base. We also shifted the CG from 50/50 to almost all on the rear or the nose. All of these are without the trailer so far, so we will try those tonight.
All I can say is I would recommend doing a few tests for yourselves. The dynamics are very different on the carpet vs. on the FRP. Set-ups that were nice and controllable on the FRP wouldn't turn if two side wheels got on the carpet, and set-ups that were easy to turn off the carpet were very squirelly on the FRP. Also, the bot lateral grip seemed a lot lower than the inline grip.
That brings up a very important point, there is a hierarchy when you design:
Ideas are great, but can often be flawed.
Fully thought out theories are better, but often involve a lot of assumptions.
Models (calculations and 3D models) are often made of some tests and measurements and some assuptions.
Test based data is even better yet especially if it validates your model assumptions.
Prototypes can be even more accurate.
My point on this is I have read through a lot of threads on how these bots should be built and how they will behave. I have a lot of vehicle dynamics experience, and I was still surprised by a couple of our tests last night.
Unread 16-02-2009, 13:05
camper365 camper365 is offline
FRC #1599
camper365 is an unknown quantity at this point
8-wheel drive
Use pairs of wheels
Unread 09-03-2009, 21:33
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Kind of late, but thought it was worth posting.
Our final configuration uses 48 wheels.
Unread 10-03-2009, 02:23
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
I want to see that. Got a picture?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 10-03-2009, 02:29
AdamHeard's Avatar
Lead Mentor
... Three days until LA.
Unread 10-03-2009, 14:09
Molten's Avatar
AKA: Jason
I won't be able to watch. Please post a pic or a vid after the fact. Ok?
6 wheel drive Shaggy1323 Technical Discussion 3 28-03-2008 17:50
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
