Go to Post It made me want to do a swerve drive, but then I smacked myself. - Nemo [more]
Unread 06-01-2009, 08:10
tiger192 tiger192 is offline
FRC #2987
tiger192 is an unknown quantity at this point
"Benchtop Test" Help!
We are a rookie team looking for some help with our benchtop test for the control system. Everything is working fine (lights,power,etc.) until we try the "tank drive" test. One joystick will power both motors, one forward, one in reverse. Joystick number 2 does nothing at all. Any help on this would be appreciated.
Unread 06-01-2009, 08:40
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
FRC #2175 (The Fighting Calculators)
Rookie Year: 2007
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Re: "Benchtop Test" Help!
Welcome to Chief Delphi,
I know that during the beta testing the default code didn't work right either and gave results like that (assuming that you are trying to use one joystick for one motor and one for the other, for a total of two joysticks).
Otherwise if you are using one joystick for tank drive (arcade mode) that is what you should get.
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
In order guarantee that tank mode works in the OTB test, DS Digital Input 1 must be grounded. Otherwise the floating input could be in any state. We had a PWM cable that only had the female connector. We tied white to black on the wire end and taped off the red before installing on the three posts.
Unread 06-01-2009, 09:03
FRC #2987
Ok, Thanks! we are trying to set up the tank drive so 1 joystick controls 1 motor, (and the other joystick the other motor) so we will try working with the pwm cable like you described and see if we get a better result.
Unread 06-01-2009, 12:45
AKA: Randy
When you ground DS digital input 1, one joystick will control the left motor and the other will control the right motor. Only the forward and backward motion will control the motors. With the jumper installed between the top and center posts of DS input 1, the joystick plugged into USB 1 will control both motors using forward/backward and left/right motions.
Unread 07-01-2009, 16:45
FRC #2987
We have tried a few different things and according to the manual, we get the exact same output for "tank" as we do for the "arcade" mode. We would like to operate under "tank" where 1 joystick controls one motor and the other joystick the other motor. Any other suggestions?
"Pinger" diagnostic program to test robot network. PhilBot FRC Control System 12 25-01-2009 16:15
pic: Team 4 Robot "Tipping Test" David Brinza Extra Discussion 11 25-08-2007 18:02
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
CMUCam blink test "blinktst.ic" mzainon Programming 1 22-04-2005 16:20
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
