Re: More Wheels?
I'm glad to see 624 won the regional at Bayou ! Go CRyptonite ! |
Re: More Wheels?
Re: More Wheels?
http://picasaweb.google.com/RazorTip...3129 88959794 |
Re: More Wheels?
We have used it in demonstrations at least through 2007. |
Re: More Wheels?
LOL i did NOT see you had already posted a picture, sorry about that
![]() And I will work on getting more pictures of that robot for you, it is still lying around SOMEwhere... Last edited by mjazzka : 22-03-2009 at 22:49. |
Re: More Wheels?
We added a 5th idler wheel today, but modified its position to not have any of the robot weight on it (ideally) to affect traction on the other 4 driven wheels. We started testing and should be able to report on our website in a few days.
Re: More Wheels?
Has anyone ever added a retractable wheel and gotten it to work? I'm not sure if thats what one of you were suggesting up top but we were thinking about trying to add a retractable wheel but we didnt know exactly how we should approach it...any ideas?
Re: More Wheels?
Is it possible (and legal) that you make pneumatics strong enough that you mount a wheel perpendicular to other wheels, then when you want to brake, you gently lift the robot using that wheel, tilting it just ever so slightly, and applying that downward pressure and braking faster?
Imagine sliding your hand over the desk, and the sliding your hand over the desk with a lot of downwards pushing..? |
Re: More Wheels?
You can only use up to 78 rover wheels in contact with the ground. No more.
#10
Re: More Wheels?
Thatz a bit harsh craig we wanted to use like 79.
#11
Re: More Wheels?
Doing some napkin calculations (read: no optimization), 112 is the hard limit for number of wheels you can have contacting the floor.
#12
Re: More Wheels?
Our Software & Controls group has done very precise calculations and found that, at least for our machine, the limit is 112.67 wheels.
#13
Re: More Wheels?
Re: More Wheels?
As soon as the robot stops accelerating upwards (and begins to coast), the force pushing down on the wheels will return to its pre-acceleration value. But a robot cannot possibly keep moving upward forever, or even offset a partial amount of its downward acceleration due to gravity. Therefore, the robot must begin to slow down its upward velocity, experiencing negative acceleration. During this period, the robot will actually have less normal force pushing down on the wheels, meaning less pushing power. So yes, you can do this; you'd just get a very limited period of increased traction followed by a limited period of decreased traction. Think of if like a roller coaster. When you go through a dip, you feel positive gee forces, and when you go over a peak you feel negative forces. |
#15
Re: More Wheels?
adding more wheels may increase your surface area, but it spreads out your weight. The net gain in traction: exactly 0. Even extra powered wheels dont help, assuming you keep the amount of power is the same. the only reason why 4 powered wheels could be better than two powered wheels is 1: more motors to power the 4 wheels, therefore more power or 2: if some of your wheels dont have traction, it's possible to pull yourself out of a bind with the wheels that do. It's a common misconception that more wheels = more traction, thats why you see so many 4 wheel drive cars in the ditch during wisconsin winters
| Has Being In FIRST Made You More Brave - More Confident? | JaneYoung | General Forum | 25 | 08-05-2007 10:11 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| Image Discuss: Wheels- you want wheels - more from team 25 | CD47-Bot | Extra Discussion | 10 | 07-09-2003 20:33 |
| More Wheelchair Wheels | archiver | 2001 | 0 | 23-06-2002 23:15 |
| More Wheelchair Wheels | archiver | 2001 | 1 | 23-06-2002 23:15 |
