Go to Post every year, Dean's speeches get better. in the process, he's also teaching people to be patient. - Winged Wonder [more]
Unread 06-01-2009, 16:45
Team 1708 Dave's Avatar
Team 1708 Dave Team 1708 Dave is offline
Lead Robot Inspector
Team 1708 Dave is on a distinguished road
Which Flash Drives work??
Our team has been having trouble updating the firmware in our DS. Tried many suggestions and none work. I remember reading a post about which flash drives are proven to work. For the life on me I can't find that post. Searched for 2 days.
Can anyone help us find a drive that is proven to work.
Unread 07-01-2009, 17:31
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Re: Which Flash Drives work??
I don't have a quote from the manuals, but I believe any flash drive that conforms to the USB Mass Storage Device spec will work (which is almost all of them). One thing to check is to make sure that the drive is formatted with the FAT filesystem. Microsoft's NTFS or Apple's HFS may not work with the Linux OS that the DS uses.
Also, make sure you're following the directions and placing the file named DSUD_PKG.BIN into the root directory of the drive (i.e. not in a folder).
If these suggestions don't work, maybe try listing what you've tried so far so we can give better suggestions.
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 07-01-2009, 19:42
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
I can verify that two Memorex Traveldrives (a 512 MB and a 1 GB) worked for us.
Again, FAT format, and make sure the file is named correctly. The download will come with a different name; you will have to decompress it and rename it for the DS to recognize it.
Unread 08-01-2009, 10:54
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
We successfully used a SanDisk. 512 meg. I do not know if he had removed the autoboot software from it.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
Unread 08-01-2009, 18:55
lingomaniac88 lingomaniac88 is offline
FRC #1554
Rookie Year: 2007
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
I have a SanDisk also. Do you think there would be a problem if the U3 software is not removed?
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
Unread 10-01-2009, 11:05
s0crates s0crates is offline
s0crates is on a distinguished road
Basically, in order to autoload their stuff, u3 makes the disk look like a usb and a cd. That would possibly prevent it from working - as far as the ds can see, you stuck in both a cd and usb. It might only look on the 'cd' drive, where their autorun exes are. The u3 stuff is probably messing it up.
btw I used a dataTraveler (Kingston?).
-jonathan
Unread 13-01-2009, 11:35
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
Smile Re: Which Flash Drives work??
We used a cruzer micro from sandisk 4gb with no problem. I was planning to use my patriot xporter 4gb but I fried it a week ago. I did uninstall the U3 stuff from the cruzer micro.
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Flash Drives in Bulk: is it even possible? JoeXIII'007 General Forum 14 11-06-2008 12:11
Drives in general Gamerboyb1 Technical Discussion 26 12-11-2007 19:28
holonomic drives Max Lobovsky Technical Discussion 5 10-03-2004 21:31
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
