Go to Post I never had any doubt; good people who do good quality work will always prosper. - Gary Dillard [more]
Unread 06-01-2009, 17:02
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
Rookie Year: 2007
rhoads2234 will become famous soon enough
Failed Benchtop test
I have searched both in CD and on FIRST Forums.
We tethered the cRIO and the DS together and when we enable the DS with the dongle, the lights on the victors still flash as if they have no signal or it is disabled.
We have triple checked all connections on the Electrical and Driver stations. Any ideas on the problem? and a solution to it?
We are using victors instead of Jaguars, could this be the problem?
Thank you in advance
Erin from 2234
ALWAYS a mechanical problem!
Unread 06-01-2009, 19:53
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Failed Benchtop test
I had this same problem helping a different team. Everything was wired correctly but I had forgotten to switch it from Auto to Tele....
Steve
Unread 06-01-2009, 19:57
m3rc1l3ss m3rc1l3ss is offline
FRC #1178 (DURT)
Rookie Year: 2007
m3rc1l3ss is an unknown quantity at this point
Just wondering, does the motors turn when you push the joystick forward? The lights will always flash if there is currently no data going through the victor/jaguar, but they should turn to a solid red or green light when you move the joystick.
Unread 06-01-2009, 20:11
Bsteckler's Avatar
Bsteckler Bsteckler is offline
Resident computer tech
FRC #2402 (JamesMonroebotics)
Bsteckler has a spectacular aura aboutBsteckler has a spectacular aura about
We set ours up w/ victors and it works. You just need to know a bit more than the directions state when you do wifi.
"Don't try anything you are about to see us do at home, ever"
-The Mythbusters
2402 scores points.
Unread 06-01-2009, 21:40
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You might simply not have completely inserted the male end of the PWM cable into the Victor's connector. It isn't obvious to an inexperienced set of fingers whether the connection is made properly. Try reseating the connector, aiming for it to go a few more millimeters deeper than it was the first time.
It might help to use a strong light to look into the Victor's PWM connector and get a good idea of exactly where the pins need to go.
Unread 07-01-2009, 06:34
rhoads2234's Avatar
AKA: Erin
FRC #2234
Rookie Year: 2007
A good thought, but unfornutely, it doesn't work when the joysticks are pushed forward (or back.)
Also it is in Teleop, and We have tried reseating the PWMs.
Unread 07-01-2009, 07:01
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
You would also see the light not come on if you don't have the dongle attached and the DS set to enable mode.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 07-01-2009, 11:06
rhoads2234's Avatar
AKA: Erin
FRC #2234
Rookie Year: 2007
The dongle is in and it is set to enabled.
We are baffled by the problem.
Should we try to re-image the cRIO?
Unread 07-01-2009, 13:18
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
Rookie Year: 2000
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
No don't think you're suppose to re-image the cRIO or update the driver station Firmware until after you have completed testing the hardware portion (what you are trying to do now), according to the benchtest manual.
Unread 07-01-2009, 16:06
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Are you sure you have the wiring in the correct direction? I believe the white wire on the PWM cable should face the inside of the digital side card and on the Victor the white wire should face towards the outside edge. Also make sure you have the digital side card plugged into the cRio via the digital expansion module closest to the network ports.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 08-01-2009, 16:32
Christine2234 Christine2234 is offline
FRC #2234
Christine2234 is an unknown quantity at this point
Yeah, we've checked all our connections on the cRIO and the electrical board. So far, nothing has changed...
It seems one of the problems is that we can't see the cRIO on the laptop. We've connected the cRIO to the laptop with an Ethernet crossover. Although the laptop can see that something is plugged in, it cannot establish connectivity with the cRIO so we can't image it. We think this is the same problem as the DS being unable to enable to the cRIO...any thoughts?
Unread 08-01-2009, 17:37
I'll have Brian from 103 respond to this, if he's unable to figure it out, how far are you from their area?
Unread 08-01-2009, 17:45
awizkid awizkid is offline
JoJo
FRC #2063
Rookie Year: 2007
awizkid is an unknown quantity at this point
Send a message via AIM to awizkid
does your digital sidecar have power? when we first set up ours we forgot to power it, without the digital sidecar being powered it cant recieve the signal from the module and can't sent out a pwm signal.
Unread 08-01-2009, 19:24
rhoads2234's Avatar
AKA: Erin
FRC #2234
Rookie Year: 2007
Yes the digital sidecar has power, all three lights(5V,6V and the one that says BAT) come on. Every other indicator that the board has that is mentioned in the Benchtop test documentation comes on.
We think there may be something wrong with cRIO. We have tried using other crossover cables to see if the cable itself was the problem, but it still won't connect to anything.
  #15   Spotlight this post!
Unread 08-01-2009, 22:08
Software Architect
Crossover cable? You should only use that to connect the camera to the cRIO's second ethernet port. All the other ethernet cables you use should be standard straight-through connections.
"Benchtop Test" Help! tiger192 Technical Discussion 5 07-01-2009 16:45
New Ctrl Sys Early Ship - Benchtop Test rrossbach FRC Control System 37 19-12-2008 00:40
Smithy or other Benchtop Mills/Lathes/CNC Dan Richardson Technical Discussion 6 21-06-2007 22:32
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
