Go to Post Two robots run in to a bar, the third one had a better driver - Wayne Doenges [more]
Unread 06-01-2009, 20:49
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
suggested gear ratios
Was wondering if anyone can give me a suggested gear ratio for this years bot at full weight running 2 cims that will give the wheels 10 fps? I know I can calculate the unloaded ratio using 5200 as the cim rpm but I don't know how to figure the rpm loss due to bot weight.
Thanks
Bruce
Gear Ratios Joe_Widen Technical Discussion 17 13-05-2006 15:06
How to calculate planetary gear ratios? sanddrag Technical Discussion 2 27-02-2005 11:55
Efficent number of Gear ratios... Matt Attallah Kit & Additional Hardware 12 14-09-2004 10:42
gear ratios roboteer49 Motors 22 29-04-2004 20:51
Gear Ratios Joshua May Kit & Additional Hardware 4 01-02-2004 22:54
