Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 07-01-2009, 03:02
obnauticus obnauticus is offline
FRC #2811
obnauticus is an unknown quantity at this point
ABS Modules/Systems Question
Hey,
I think it would be a really good idea to design good breaks and "lock" sensors on each of the wheels so one could theoretically take an ABS system/module from a car and integrate it into the FRC kit/Robot (with the pinout(s) and detailed documentation and basic logic). However, I cannot find any documentation on any modules (they are extremely proprietary) and specifics on "lock" sensors (that's the most detailed description I could find). By moving the ABS calculations to a different system--it should save precious processing power. This way there can be faster response times for image recognition and other things which are also crucial to the real-time calculations that the cRIO may have to do.
I am wondering if anyone here knows of an easy to use and welly documented ABS module. This would enable a team could integrate it into their current control system (with the addition of sensors and breaks). I couldn't find any DIY solutions for ABS modules that other people may have designed for robots on Google.
Thank you in advance
modules for RC PLANE mogli General Forum 5 16-11-2008 11:11
ABS Electronics Board Ian Curtis Electrical 3 07-01-2008 23:25
Using CCP modules steven114 Programming 7 13-02-2006 12:43
Vishay IR Reciever modules EIROBOTICS86 Electrical 4 04-02-2004 00:18
RF Modules archiver 1999 1 23-06-2002 22:06
