Go to Post Organization is the one skill that can help make *any* workshop work. - tjf [more]
Unread 07-01-2009, 17:02
RyanJK's Avatar
RyanJK RyanJK is offline
Does it come in chrome?
AKA: Ryan Kamphuis
FTC #3758 (Juarez Aztec Eagles)
RyanJK is on a distinguished road
Help! Connecting CRIO to the Power Block
Hey everyone! So, this year the torch has been passed to me to be the electrical dude. Last year we had someone who actually was studying electrical engineering, but I have no clue and I'm in over my head. I've been able to wire the battery to the power distribution block through the circuit breaker, but now I'm trying to connect the cRIO to the block. I've read in the manual that I need to use 22-14AWG wire. I really don't know what that is, and looking through the inventory list, I don't think any came in the kit of parts.
Also, I know how to use a volt meter to check voltage, but I was wondering if anyone can describe to me how to use the voltmeter to check if the right amount of amperage (40A, 30A, etc.) is coming out of each spot on the power block.
Thanks everyone! I'm the one who knows the most about wiring in the team, but that isn't saying much. We have a mentor coming in a couple days, and he's gonna teach me what I need to know, but he asked me to do this before he came...
Ryan Kamphuis
Head Mentor, FTC 3758
FRC Game Announcer
Member of the Midwest Regional Planning Committee
2012 - 2015 Chicago, IL Kickoff Coordinator
Alum of FRC Team 2526! Go Crimson Robotics!
Unread 07-01-2009, 17:14
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Help! Connecting CRIO to the Power Block
http://www2.usfirst.org/ftpdoc/coordination/
Check out the above information from the Robot Quick Build Session. There is a LOT of great info on this FTP server.
Before turning on the power, you'll definitely want to have your mentor check out your wiring job.
Regarding wire size, I use the following link very often to compare gauge (related to wire diameter) versus resistance and current handling capacity. Larger diameter = less resistance and more current capacity.
http://www.powerstream.com/Wire_Size.htm
Russ
Unread 07-01-2009, 17:22
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Bah, you'll be fine. You are asking the right questions and reading the manual. You'll be teaching others before you know it.
AWG stands for American Wire Gauge. 22-14AWG means between 0.644mm and 1.628mm, if you look at the chart that is about half way down that link.
It isn't a good idea to use a multimeter to check for currents in that range - you are likely to damage it. Basically, your meter will draw as much current as is possible. You then need to hope that the circuit breaker blows before the meter or the wires do. You will have to rely on the labels on the circuit breakers.
Always figure out what will limit the current before you measure it. For example, the 5V/6V supply that is featured on the PD, DSC and Analog Breakout has a very good fast acting current limit that will cap instantaneous current to 5 Amps. My multimeters are typically fused at 20A, so they can measure there. Check twice!
Unread 07-01-2009, 17:28
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
Rookie Year: 2000
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Seems like you think that if you plug the meter into a slot with a 40A breaker it will show 40A on the meter. This is not correct. When you use a meter to measure current, it will tell you the current flowing through at that moment (the amount of current needed to power the device).
You can use it to measure current for smaller devices. But like Eric said I do not recommend using one of those probe meters to measure the current going through a motor (sometimes up to 40Amps). Meters aren't able to handle that.
For motors and high current devices, what we use is a meter that clamps around a cable to check the current flowing through it (rather than the one with just probes).
To measure current with a meter with probes:
1) Plug the black probe into COM (common)
2) Plug the red probe into the ADC port (might say like 10ADC)
3) Turn the dial to point to the indicator for dc current (DCA or maybe A with a solid line over it)
4) Wire the meter in SERIES with what you would like to measure the current for. Voltage is measured in parallel, current in series.
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
Connecting Power Distribution block to cRio Paul Rodi Electrical 2 05-01-2009 18:20
24v Power Conector to from the PDB to the cRIO mcf747 Electrical 14 01-12-2008 19:19
need help with power dist block & maxi bkr steve d Electrical 4 07-02-2007 18:07
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
