Go to Post New CAD computer one day and the 254 Build Blog Tech Binder the next? Christmas in July really does exist. - [more]
Unread 07-01-2009, 19:19
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Crio network light does not light when camera plugged in
When we plug our axis camera into the cRio, the network light does not light up.
-We are using WindRiver for development (we don't have Labview installed. Should we?)
-We can successfully upload programs to the cRio
-All our IPs are set correctly
-The camera is connected using a crossover cable on port two
-The camera has the FRC/FRC account set
-The camera powers up fine (it turns orange for about 10 seconds, then green).
-We have successfully viewed camera output in our browser when the camera is directly connected to the PC
We have no idea why the camera doesn't even seem to attempt to communicate with the cRio when we plug it in. We know that the cRio's port works because we can plug our tether into it and it works, and we know the camera's ethernet port works because we can view it and modify settings if we plug it directly into our PC.
Did we miss a step in instructions? Has anyone else had this problem? I searched extensively and couldn't find anyone talking about the network light not even lighting.
camera goes to corner when finds light iiiii Programming 5 13-02-2007 13:20
easy-c camera goes to corner when sees green light iiiii Programming 0 12-02-2007 19:07
Camera finds overhead lights not green light theycallhimtom Programming 4 20-01-2007 17:37
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
