Go to Post It isn't what you're given that makes it awesome. It's what you do with it. - JosephC [more]
Unread 07-01-2009, 20:49
Applepwns's Avatar
Applepwns Applepwns is offline
Likes Waffles
AKA: Justin Murphy
FRC #0201 (FEDS)
Team Role: Marketing
Applepwns is an unknown quantity at this point
Diagnostic Light
How do you wire the orange diagnostic light this year?
Thanks
Unread 07-01-2009, 21:41
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: Diagnostic Light
looks like just two wires. No need to mess with a relay.
http://usfirst.org/uploadedFiles/200...%20diargam.pdf
Unread 07-01-2009, 21:43
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Yup,
plugs right into the new control system with no relay hook up. Wiring only that's necessary.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 07-01-2009, 22:06
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
what gauge wire should we be using for that? is 14 awg overkill?
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 07-01-2009, 22:45
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, 14 AWG is overkill. Since it is powered via the Digital Sidecar, and that is protected by a 20A breaker, accoring to <R45> C you need 18 AWG.
Unread 07-01-2009, 23:42
CDH Jeff's Avatar
what does it mean in the wiring diagram how it has the + split and going into both of the ports on the light? are we supposed to split the wire or just have it go into one or the other?
Unread 07-01-2009, 23:46
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
Rookie Year: 1997
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
To get the signal light working properly, you need to short La and Lb as your positive terminal, and use N as the negative terminal. This is the procedure used in 2007, and worked for FRC 41 this year.
You'll then probably want to splice into a 2 pin connector like one supplied in the kit. You can use a lighter gauge because, according to the DSC data sheet, the RSL pins only supply something on the order of 2A.
-Jeff Erickson, FRC41
Unread 08-01-2009, 07:47
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Jeff,
The two connections to positive power is so that the light can be controlled by the sidecar. Wired this way, flashing control can be initiated in the sidecar. The light has other uses which take advantage of the control input (third connection) on the light.
I am going out on a limb to suggest #18 wire for the light. I will make some inquiries so watch for a team update addressing this.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-01-2009, 10:25
FRC #6357
Rookie Year: 1997
Al is right, shorting the La and Lb terminals allow the DSC to control the light.
If you play around with it a bit, you find that when contacting one terminal (I forgot if it is La or Lb), the light flashes with some internal mechanism. When shorting the terminals, the light is steadily on. So, shorting La and Lb allow the pulses from the DSC to flash the light. This allows the "fast flash" (disconnected), the "slow flash" (connected but disabled), and "steady on" (connected and enabled).
Also, our light drew about 1.3A when on.
-Jeff
Unread 08-01-2009, 12:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by jee7s View Post
...our light drew about 1.3A when on.
While that's a useful bit of information, it's mostly irrelevant to the question of wire size. You need to choose wire that won't melt before the circuit protection kicks in to cut off the current. Don Rotolo gave the officially correct answer (18 AWG) based on the breaker protecting the entire Digital Sidecar, though a different answer might be possible based on detailed knowledge of the light driver circuitry.
Unread 08-01-2009, 13:05
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Per the Digital Sidecar datasheet, the Robot Signal Light is protected by a PTC, at 2.2 amps
Unread 23-01-2009, 09:54
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
For reference - RSL states and meaning doc just posted on NI's website.
http://decibel.ni.com/content/docs/DOC-3120
Russ
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
Diagnostic light? Zack Briggs Electrical 5 06-02-2008 01:34
The Diagnostic Light? Dan Man Electrical 5 22-02-2007 22:04
diagnostic lights Breeze Electrical 3 14-02-2007 20:36
cmucam2 Diagnostic? muy dificil Programming 0 11-11-2005 11:26
