Go to Post Please don't confuse energetic enthusaism with acting obnoxious. - Alan Anderson [more]
Unread 07-01-2009, 23:14
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Friction and thrust
I've been keeping up with "Propulsion that does not involve driving wheels" (and even contributed to derailing it), and have had this going through my head the last day or so:
Part 1: Friction
Assume the robot, battery, bumpers, and trailer tongue weight add up to 150 lb. With a coefficient of friction of 0.08 (on the high end of experimental data), the lateral force available for acceleration can be as high as 12 pounds. That's just the normal force (due to the total weight on the robot wheels) times the coefficient of friction, independent of wheel configuration.
Part 2: Thrust
(My apologies in advance for using non-standard terms for this, it's not really my field. Feel free to provide the correct syntax.)
I looked up equations for thrust (on wiki) of a driven fluid, which is the product of the mass flow and the velocity of the fluid. Using a value for air density of 0.075 lb/ft^3 and a flow rate of 60 ft^3/min or 1ft^3/s gives a mass flow of 0.075 lb(mass)/s. Forcing this through a nozzle at 100 ft/s, you'll get a thrust of 7.5 lb. Based on what teams did last year, this seems like it might be possible with a scavenged shop vac or leaf blower impeller.
Is that thrust calculation right, or even in the ball park? Could a jet-assist directed laterally really give a 60% or greater boost to the drive train?
- Steve
Unread 08-01-2009, 01:04
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
Team Role: Coach
Rookie Year: 2007
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: Friction and thrust
Electric Ducted Fan Airplanes generally perform at about 2 - 3 g/w where the watts are input watts (not motor watts). This is your starting ballpark and it translates to about 29 ounces of thrust from 330 watts of input power.
The only reasonable candidate motor for this is the fisher price. You could get perhaps 1 - 2 lbs from each.
IIRC we have to protect the FP motors for 30 amps. Allowing for some loss in the speed controllers we should get a shaft output of 150 watts if can present a torque load of about 21 oz-in with a motor speed of about 10,000 RPM. The motor could probably be pushed to 40 -50 amps for short times. You will need to find a propeller or ducted fan unit that can fit the motor and provide the suitable load. Ducted fan units in the right size range are generally sized for 1 - 2 kw brushless motors.
There are obvious safety hazards. The ducted fans are a bit safer.
I am a little surprised that FIRST hasn't closed down this option by rule. Its one thing to have 10,000 RPM in a closed gearbox and quite another to have it on a 3 - 8 inch rotating cutting blade. A rule say limited rotating parts to 3-5000 rpm-inches of diameter would take this off the table.
Contact Area and its Relation to Friction? Qbranch Technical Discussion 51 17-01-2008 09:31
Friction and Trackballs pfreivald Technical Discussion 7 11-01-2008 09:49
pic: Team THRUST is done! Wayne Doenges Extra Discussion 9 17-01-2007 19:31
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
