Re: Conveyor Belt
![]() The screw lift does take up a lot of room, but most of that room is used to store balls, so it's not wasted. |
Re: Conveyor Belt
We tried to make a screw lift in 2006 and it didn't work out for us. I kind of hope we can at least get a good prototype this year because I think they look really cool.
In our final 2006 design, we used a conveyor belt from flat conveyor material that was very effective. We used pvc pipe (with many "speed holes") with end caps for the rollers. We could pick up balls really well with it, and fairly easily get two balls side by side. (Unfortunately the shooting was not so good...) That said, a preliminary hand powered prototype vertical conveyor with four strands of surgical tubing worked pretty well lifting the orbit balls up 3 feet last night. One key is having a good surface opposite the conveyor to help maintain the force on the balls. The conveyor worked well enough that the render of the robot with the conveyor is still hanging on my classroom wall. Another thing to watch out for the conveyor mangling the balls if they stay and and get pulled back down. In 2006 we would occasionally pull the balls through a 2 cm opening between the conveyor and the chassis if the hopper was full. That would probably destroy the orbit balls. |
Re: Conveyor Belt
Anybody know how to go about shortening and reataching a treadmill belt??
Thanks Bruce |
Re: Conveyor Belt
There are certain materials that we have discovered to grip orbitballs extremely well..... (a little hint: bedroom would be incomplete without a dresser that can hold clothes in place....) My advice if you cant figure this out, is to bring an orbitball on a date to a hardware store an run it through any materials.
Re: Conveyor Belt
Im looking for some urethane belting material and am trying to find a cost effective way of bonding the stuff. Anyone have any ideas?
Re: Conveyor Belt
Does it need to be urethane, or would something like neoprene work? You might experiment with some Pliobond contact cement.
http://www.mcmaster.com/#conveyor-belts/=fxqrh |
Re: Conveyor Belt
http://www.chiefdelphi.com/forums/sh...light=polycord |
Re: Conveyor Belt
It's kinda funny how things work out.
In the last 3 weeks we've tried everything we read on these forums, and it was always one thing or another that went wrong. Finally, last night we came up with our own solution to this that hasn't been suggested on these forums. What we found left some black residue behind, so once we test 2 more materials that are coming in Thursday I'll post what we've done. I knew once I found this stuff when spelunking through TrueValue in Week 2 that we should have used it right away, but alas I'm not the only one on the team. My tip: stay away from Lowe's and Home Depot when in a search of local hardware stores; they're too big and you'll spend way too much time looking for the right thing. Start with the mom and pop shops that are small and have everything closer together without all of the non-relevant items in between them. On top of that, usually you can touch/sample a material without opening an entire box. Then, once you have an idea of what you want, purchase the sample and test on the prototype. |
Re: Conveyor Belt
Our conveyor is driven very fast by a modified FP motor which I detialed in another post: http://www.chiefdelphi.com/forums/sh...t=72513&page=2 |
#10
Re: Conveyor Belt
Best of luck |
#11
Re: Conveyor Belt
Yesterday we got in our two test materials, and they work like a charm when used together. I will say that we don't intend for our conveyor to go extremely fast like some people have posted, so YMMV for this setup.
The first is a nylon mesh, with tiny holes. With a belt that's 6" wide, this stuff simply does not break. After putting a sample in the vise and yanking on it, and on two glued pieces, all we found was that we were getting more and more tired of trying to break the stuff. It showed no signs of fatigue, neither on the material nor on the glued join. However, it does not grip the ball like I though it would. The second material is a neoprene mesh. It turns out that the mesh has 'teeth' that grip the ball ridiculously well in one direction, yet it has a worse grip than the nylon in the other direction...I wonder what we can use that for... It's downside is that it is extremely fragile. But combine the two with some hot glue... and BAM a ridiculously strong, flexible, lightweight belt that is cheap ($40) and easy to make (don't stretch the neoprene when bonding the two though!). We also have a small sample of the two materials expoxied together, so tomorrow we'll see how well that worked out. /edit I should also add that we're using this material as a tread to drive the belt. Last edited by JesseK : 06-02-2009 at 10:49. |
#12
Re: Conveyor Belt
-Vivek |
#13
Re: Conveyor Belt
we're doing a conveyor belt design and i need to know what kind of motor would be best for a conveyor belt?
#14
Re: Conveyor Belt
I hate to put it like this, but the answer is: it depends.
For our conveyor, we're using only 1 window motor. With our roller, it gets the balls through 40" of conveyor in 5 seconds. This is acceptable to us, as the motor has more than enough torque and the speed is 'fast enough'. We also are trying to conserve weight, so more motors are impractical right now. (Our drive train + pneumatics + electronics board came in at 65 lbs ) |
#15
Re: Conveyor Belt
Ah, the designs my former team has produced for a screw type lift only accommodate one ball. What are you planning on driving it with?
| Conveyor Belt | Setsanto | 3D Animation and Competition | 2 | 21-01-2008 20:51 |
| conveyor belt materials? | Salik Syed | Technical Discussion | 7 | 13-02-2006 14:51 |
| Conveyor Belt | Garth1388 | Inventor | 4 | 30-01-2006 13:33 |
| COnveyor belt wheels | sdcantrell56 | Technical Discussion | 4 | 18-01-2006 00:10 |
| vertical conveyor belt | ahecht | Technical Discussion | 3 | 15-02-2002 16:16 |
