Go to Post The unlived life is not worth examining; the unexamined life is not worth living. - Sage-Theory6 [more]
Unread 08-01-2009, 18:59
TheGreaterNate TheGreaterNate is offline
FRC #2975
TheGreaterNate is an unknown quantity at this point
Brakes
We're a rookie team, so bear with me on this. We've read and reread the rules, but there always seem to be interpretations we don't think of.
Is there anything in the rules that would prevent using wheels as brakes? Our thinking is that we can attach wheels that are frozen in place which can then be lowered for braking purposes.
Unread 08-01-2009, 19:00
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Brakes
Nothing is illegal in the rules about doing that. However, you would need to use the slippery wheels.
Unread 08-01-2009, 19:14
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: Brakes
I agree that this is totally legal. You would want to use the wheels in a Transverse direction to double the dynamic coefficient of friction.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 08-01-2009, 19:17
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Brakes
Legal as long as they're the rover wheels. If it's any other wheel, you guys are not going to get past inspection.
The fun part is going to be locking them in position and getting them down.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-01-2009, 19:18
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
Re: Brakes
There is nothing illegal about this plan. Do realize though, that this will most likely not produce results different than simply stopping your drive system. According to Physics, the surface area should make no difference on traction on an ideal surface. As you increase the surface area, you decrease the weight per unit area, thus canceling any gain in traction. The field this year is REALLY close to an ideal surface, so you would get no "velcro effect" from the wheels simply resting on the field like with carpet. Usually on carpet, this velcro effect will increase with the number of wheels and offset the friction lost to weight spread.
P.S. I tried to explain it the best I could, but it is still probably confusing. Let me know if you have questions.
Can you play Crysis?
Unread 08-01-2009, 19:37
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Re: Brakes
You will need to consider if this will damage the floor, if so I would suggest thinking of something else.
- Arizona North
Unread 08-01-2009, 19:39
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Talking Re: Brakes
if im not mistaken you can as long as only 2009 rover wheels are touching the floor
Unread 08-01-2009, 19:50
CJBrick CJBrick is offline
FRC #1296
CJBrick is an unknown quantity at this point
Re: Brakes
Whats the maximum amount of rover wheels you can have? because you could lower the wheels as they say. but what if you have a bar of 6 wheels that comes down. and has a lot of resistance but still spins on a spring or something. i am a rookie myself but my team is veteran so don't dis our team for my dumb ideas but just
Unread 08-01-2009, 19:52
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Brakes
No limit to how many wheels you can have, unless you count that they all have to fit in the sizing box in the "normal" orientation.
Past teams:
Unread 08-01-2009, 21:09
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: Brakes
While this is true, according to FIRST and my team's own tests, the transverse coefficient of friction is different that then inline. This means that if you mount the "brake" wheels perpendicularly (rotating around the y axis), they will produce more friction than otherwise. This is because the frictional force is the product of the coefficient of friction and the normal force (weight) on each wheel. Now you're dividing the weight of the robot over more wheels (unless you pick up the other wheels, which is technically an option), but you've increased the coefficient of friction. You'll have to decide for yourself whether this is what you want. Make sense?
For all of you running your coefficient of friction tests, make sure you do them loaded. Yes, I know the physics, but we all know reality. Just trust me on this.
Unread 08-01-2009, 22:02
zachjo's Avatar
zachjo zachjo is offline
Shake 'N' Bake
FRC #0171 (Cheese Curd Herd formerly Extreme Engineering)
zachjo is a jewel in the roughzachjo is a jewel in the roughzachjo is a jewel in the rough
Re: Brakes
something you might also want to consider is setting the speed controllers to brake and not coast, although it probably won't help much on this floor.
unicycling----It's like doing a wheelie forever!
Shake 'N' Bake
Unread 08-01-2009, 22:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Brakes
As has been explained to me (thanks Raul! and I hope I am stating this right) adding wheels does nothing to increase the friction between the robot and the floor. As the surface of the floor and the wheels are both extremely hard and flat, they approach ideal surfaces. Theoretically, if the weight of the robot remains constant, the amount of friction applied between the robot and the floor would be the same with one wheel, four wheels or a flat plate as large as the robot.
As to using the Brake mode on the speed controllers, this works best when their is some amount of friction between the floor and wheels. The braking action is then a function of the rotational speed of a motor. The greater the speed, the more current flows into the controller and a greater back EMF is produced at the motor. At low speeds there is very little current and hence very little back EMF. I am prediciting that in this game, supreme control over wheel rotation, moving and braking, will prove to be the single greatest factor to stable driving.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-01-2009, 22:43
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Re: Brakes
I agree that surface area has nothing to do with friction. Now, yes the lateral friction is higher...by almost a tenth if im not mistaken.
Personal opinion...not worth the time or space. again PERSONAL opinion .........great now some teams gonna do it and show me up at comp
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Brakes
Would the above hold true if the coefficient of friction suddenly increased? i.e., locking the wheels so that they are 90* to the direction of motion, then lowering them and raising them as needed?
It wouldn't apply for wheels locking while traveling straight ahead, but maybe for that transverse friction...
Past teams:
  #15   Spotlight this post!
Unread 08-01-2009, 23:01
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Brakes
According to our tests, inline and transverse friction is either exactly the same or very slightly different (say less than 5%). Whatever it is, it definitely isn't double transverse than it is inline.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Brakes paulcd2000 Rules/Strategy 9 04-01-2009 12:49
Victor Brakes xtolbert_gators Electrical 30 18-01-2007 12:57
Disk brakes JohnMorenski General Forum 35 21-12-2006 13:33
Brakes pakrat Technical Discussion 34 06-05-2006 11:45
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
