Go to Post If you pay attention to every nut job on ChiefDelphi, you'll never reach a decision. - JesseK [more]
Unread 08-01-2009, 19:29
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Rookie Year: 2007
Team1710 is an unknown quantity at this point
Camera Help
We're trying to just test out the camera at this point and make sure its working properly. We've plugged it in, hooked it up to my laptop using the orange crossover cable, set my Vista IP on my laptop to 192.168.0.192, shut off my firewall, disabled all other connections and tried my browser to the address 192.168.0.90. We can't get anything to come up...it just times out.
We tried to open the FRC Axis Camera Managment and it pops up--at first, it says something similar to "setting up camera accounts", but then gives us an IP error claiming the computer isn't plugged in or there is an IP confilct error.
I've run into a wall and need some help.
Thanks!
Unread 08-01-2009, 19:54
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Camera Help
What subnet are you using?
That might be your problem
We had success accessing it with the ip 192.168.0.50 with the 255.255.255.0 subnet
Unread 08-01-2009, 22:10
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Camera Help
Make sure all other network adapters on your machine are disconnected, or even disabled.
Eric Haskins KC9JVH
Camera [help] beefy1 Programming 1 25-12-2008 15:44
Camera HELP! yarb65 Programming 5 29-01-2007 21:58
Camera Help itzrobz Programming 15 24-01-2007 17:18
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
camera help! |20807 61|2|_ Programming 5 08-01-2006 14:44
