Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-01-2009, 22:56
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Wheel Wear
ok so we are all going to test our bots. Some of us dont have the field surface and we may be practicing on our shop floor. soo heres my questions
how do yall think first will deal with worn wheels due to testing?
Unread 08-01-2009, 23:02
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
Re: Wheel Wear
In the rules it says <R06>"The surface tread of the ROVER WHEELS may not be modified except
through normal wear-and-tear."
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 08-01-2009, 23:12
Iceman1330's Avatar
Iceman1330 Iceman1330 is offline
FRC #2523 (Lab Rats)
Iceman1330 is an unknown quantity at this point
Re: Wheel Wear
I'll also direct you at <R06>
"The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game"
Anyone hoping to wear their wheels before the competition as an advantage for traction needs to give themselves an ethics check. FIRST rules, as we all know, are about intent, not lawyering.
In your case, it might be unavoidable wear and you might not have the budget to replace the wheels. However, if you know wheel wear is going to be an issue, pick up some more if you can to comply with the intent of the rule.
Unread 08-01-2009, 23:17
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
Re: Wheel Wear
haha gotcha... man i need to change my train of thought. in FSAE racing, its allabout bending and pushing to rules to get MAX performance lol
hmm, we only have our shop space to run. Now its not as rough as sidewalk concrete but its not the smoothest surface ever. And i know ALOT of teams that only have a parking lot to run...
Unread 09-01-2009, 17:58
Prontopwnage Prontopwnage is offline
FRC #3070
Prontopwnage is a glorious beacon of lightProntopwnage is a glorious beacon of lightProntopwnage is a glorious beacon of lightProntopwnage is a glorious beacon of lightProntopwnage is a glorious beacon of lightProntopwnage is a glorious beacon of light
Post Re: Wheel Wear
lolz you could wear your wheels down so its really rough and you would gain a bit of traction but not much...
But this really a techicality... so if you do this you can get skrewed over by the judges... and have to switch wheels, so... idk
Unread 09-01-2009, 18:58
Hanna2325's Avatar
Hanna2325 Hanna2325 is offline
Programmer/Driver
AKA: Hannah
FRC #2177 (Robettes)
Team Role: Driver
Hanna2325 will become famous soon enoughHanna2325 will become famous soon enough
Send a message via AIM to Hanna2325
Re: Wheel Wear
I'm sure what ever u guys are doing will be considered "normal" but if ur planning on some intense driving practices u probably could order more wheels just to be safe.
Unread 09-01-2009, 19:39
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Wheel Wear
If you guys want a good surface to test on, I suggest some clean tile flooring that is in most schools inside. We had a sample of off-brand regolith and compared it to our tile flooring and got similar numbers.
I see no reason why a school wouldn't have tile somewhere.
If it's an issue of "there's other people there", just wait until after they've left and then go use the room. Just make sure to leave it in the same condition you used it in -- wouldn't want to get in some trouble because you messed it all up.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 09-01-2009, 19:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Wheel Wear
If you are trying to wear your wheels for more traction at a competition: good luck! You will more than likely wear one more than the others, which means one of the wheels probably will not touch the surface. On top of that, it's fairly difficult on this field to keep all four wheels with the same amount of traction if you modify them. (A mu difference of 0.01 with these wheels is a +- 20% amount of traction...)
So, 'normal wear and tear' from your shop -- I wouldn't worry about too much. I'd imagine that the GDC expects that everyone will want to practice ahead of time and that not everyone has an ideal field to do so.
GitHub
Unread 09-01-2009, 20:01
Clayton Rogers Clayton Rogers is offline
FRC #1006
Clayton Rogers is an unknown quantity at this point
Re: Wheel Wear
We tested on the school floors and got .25 co-efficient of friction and also tested on the actual surface and got .07. So we concluded that the school floor were several times stickier than the actual surface, but still very slippery and probably still good for practice. Also note that our school floors were not very clean and had some dust/dirt.
Unread 09-01-2009, 19:55
Mike Wittman's Avatar
Mike Wittman Mike Wittman is offline
Plastic Man
FRC #1714 (More Robotics)
Team Role: Coach
Mike Wittman is an unknown quantity at this point
Re: Wheel Wear
I have to take issue with your "Skrewed over" comment. The judges and refs are there to uphold the rules not Skrew people over. As a matter of fact I find them to be very helpful to teams that don't satisfy the rules.
Mike
Tie two birds together, though they have four wings they cannot fly
www.morerobotics.org
Learn More, Give More, Be More
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Team Role: Teacher
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: Wheel Wear
This will more then likely come down to the head inspector (in many cases) at the regionals/Champs. "Normal wear" in my book, is light scratching of the tread area, that would resemble a razor slit. There should be very few side to side "slits" and a fairly constant diameter slit. These slits will be hard to be done without testing, because as some have found out, the slits tend to be spuratic and very inconsistent on the tread of the wheels. In a nutshell, I believe the only issues that inspectors will have, is with team who have altered their wheels, gracious professionalism will need to be used by teams to make sure that they do not alter their wheels to appear "more used" then normal.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 09-01-2009, 20:10
JesseK's Avatar
FRC #1885 (ILITE)
Re: Wheel Wear
Originally Posted by sejeff View Post
Mike is right, the judges will do everything in their power to help you get approved and out on the playing floor, that's why I love them.
I completely agree. They know that you've put 6 weeks of blood, sweat, and <sometimes> tears into the thing...so not being able to play at all is definitely not what they want. Between all of the available resources, you will somehow find a compromise and be able to play so long as you agree to their terms...which are always in my experience within what the GDC puts out.
1885's own example:
In Atlanta '08, on Friday a ref (who was also an inspector on Thursday) noticed an angle connection on our radio modem serial port. We put our controller 1.5" from the rear of the robot. No big deal we thought, since we could put an angle on the radio modem connector and connect the radio while staying within the dimensions. Little did we notice that the connections themselves were not allowed to be modified in ANY way, which the ref pointed out to us with the rulebook. We made it through 2 regional competition inspections and Atlanta inspections without a single word to us, so our plea to the head ref in Atlanta was for us to keep the angle connector on. His compromise in return was that we were not allowed to dispute a match in which our robot stopped responding due to communication issues, as was his interpretation of the intent of the rule. We were allowed to compete if we agreed, which we did. Believe me, we're triple checking our compliance with the specifics this year!
GitHub
Unread 09-01-2009, 22:38
907eyci's Avatar
907eyci 907eyci is offline
drop TESTer FTW
FRC #0907
907eyci can only hope to improve
Re: Wheel Wear
well for testing we had a good idea of a hockey areana.. but we are kinda in Canada so they ant soo hard to find up here.
Unread 09-01-2009, 22:42
CraigHickman
Posts: n/a
Re: Wheel Wear
I have a serious problem with some of the logic presented in this thread. A true FIRST student would hear that the wheels gain traction as they wear, and rather than thinking pushing the rules to the max, they'd see that this REALLY means. Folks, design your robots to allow easy swapping of wheels. If FIRST sets a max amount of wear, you don't want to have to take your entire robot apart to change out a few wheels.
  #15   Spotlight this post!
Unread 09-01-2009, 23:25
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Re: Wheel Wear
We have not tested our wheels out yet on the Robot but i really, really hope the wheels do not wear down as quick as people say they do. First is expensive enough with out have to have a ref demand you change your wheels out every regional.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Wear Sunscreen Herodotus Chit-Chat 1 18-05-2008 18:22
Tread Wear RyanN Technical Discussion 21 09-11-2007 22:18
Wheel wear??? 6" Pneumatic tires??? Scott358 Technical Discussion 11 29-03-2003 13:35
I wear eye glasses... archiver 2000 3 23-06-2002 22:32
