Go to Post It will be really cool if it works, sad if if doesn't. We got our fingers crossed! - falconmaster [more]
Unread 09-01-2009, 14:16
Zorkinian Zorkinian is offline
AKA: John Gilbert
FRC #0488 (Xbot)
Zorkinian is on a distinguished road
Timing with the Driver Station
Does anybody know the rate at which packets arrive at the cRIO from the driver station? Is it a constant?
Unread 09-01-2009, 17:47
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Timing with the Driver Station
I can't find anything specifically, but I would say it is not constant. It's a TCP stream as far as I am aware.
You probably shouldn't depend on DS packet timing, but instead use a different timer which you can control.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 09-01-2009, 17:51
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Is there a way to calculate delta time in Labview?
Unread 09-01-2009, 19:30
AKA: John Gilbert
FRC #0488 (Xbot)
There may be a way, though I haven't tested it. Under Real-Time -> Real-Time Timing there is a tick count (presumably of the processor) that you read from, which you can also set to mSec or uSec, which would probaby get you the resolutino you need.
Unread 09-01-2009, 23:25
Under Timers, use Tick Count. It's millisecond resolution so it should be enough. Then just save the value through whatever method you want and subtract from the current Tick Count whenever you want the delta.
Unread 09-01-2009, 23:37
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
50Hz (it's in the headers if you look)
Unread 10-01-2009, 09:42
FRC #1094
Thanks for the info on delta time, I'll create a shift register.
Help with updating firmware on Driver Station urg8rb8 FRC Control System 3 28-12-2008 02:53
Securing the Driver Station? Madison FRC Control System 16 16-12-2008 03:05
Mounting the Driver Station...? 1708xMr.Roboto FRC Control System 1 15-12-2008 12:34
pic: The new driver station Billfred Extra Discussion 28 23-04-2008 20:07
pic: Why FIRST needs to make the driver station taller Jay Trzaskos Extra Discussion 12 12-03-2007 08:57
