Current Measurement
Our programming team would like the ability to measure the current drawn by the various motors on our robot. The new Jaguars are supposed to have this ability built in but unfortunately we are not allowed to use that feature this year.
I do not know enough about measuring current to guide them but have searched the various electronics supply house catalogs (Digikey, Mouser, Allied, etc.) for current sensors, etc. and am now convinced I know even less than I thought I knew before. I had been under the impression that we were never allowed to place anything inline between the power distribution and the speed controllers but under careful rereading of rule <R44> I’m not so sure that is the case: <R44> Custom circuits shall NOT directly alter the power pathways between the battery, Power Distribution Board, speed controllers, relays, motors, or other elements of the robot control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, because the effect on the ROBOT outputs should be inconsequential. Could someone please assist me in how we can measure current drawn by the motors while maintaining compliance with the rules? Specific part numbers, links to online references, schematics/circuits that teams have used in the past, etc. would be most helpful. I am NOT an electrical engineer but I am envisioning a sensor that connects between the power distribution board and the speed controller and then to the analog inputs that has a 0-5V output proportional to the current being drawn by the motor. For those that are familiar with them, we have a Medusa Power Analyzer that we use in testing and are looking for similar “real time” functionality on the robot during competition. Thanks! |
Re: Current Measurement
This is the sensor I used for current monitoring for the battery monitoring boards:
http://www.gmw.com/magnetic_sensors/...csa/CSA-1.html Pretty easy to use, though I'm not sure I like the accuracy. Benefit is that it is easy to change the sensor's range. Allegro sells some internal hall effect current sensors. http://www.allegromicro.com/en/Produ...rentsensor.asp |
Chuck,
Many years ago we developed Stangsense using a MAX4172 Maxim high side current monitor. We simply made a series of one foot long #10 wires with a sense lead at each end. The MAX4172 then measures the voltage drop across the wire (which is ~0.1 volt/ft/100amp) and then ported that to a A/D and some multiplex circuitry to a digital input on the IFI controller. It then allowed us to port that into the dashboard stream which we configured a Palm to accept data from and we had data on current from a variety of motors along with the sampled battery voltage which was part of the dashboard stream as well as other useful items. I believe the schematic resides on CD here someplace for the price a search. |
Thanks for the info guys! Keep it coming!
Al, I searched and boy "Stang Sense" was way back there starting about 2002! I read through the treads and most of the links to the schematics seem to be broken though. This one asks for a username and password. Is there anywhere else it might still be available? |
Shameless plug for my workplace.
You need to use something called a shunt for accurate current measurement: http://bluesea.com/category/6/24/pro...e/overview/202 pn9230 Analog Meter Shunt 100A/50mV This means that at 100A there is a 50mv difference in voltage at the sense leads. Amplify this, and run it to an Analog port on the cRIO. Here is an application note that will explain it all for you: http://www.maxim-ic.com/appnotes.cfm/an_pk/746/ |
Ok, after some more searching I think I have found a current sensor exactly like what I had envisioned but I still don’t know if it is legal per the wording highlighted above in <R44>.
Are these Phidgets line of current sensors legal per <R44>? I know CD in not the official word on legalities, I am asking if the general opinion is or is not that these Phidgets current sensors would be considered “low impedance current monitoring circuitry” per <R44>? 50A : Manual 30A : Manual 20A : Manual If they are legal then they seem like they would be easy to connect to the cRIO analog inputs and program to read the current draw thus exactly solving our problem. These are available from several places including Trossen Robotics. |
I am having the same problem and it won't allow my user and password in. I found the schematic here on my home computer so I have attached it. I am pretty sure it exists here on CD someplace but here it is again. |
So I think that is what the rule considers to be “low impedance current monitoring circuitry”. |
I cant read that schematic but it looks way more complicated then it needs to be. The MAX4372 from Maxim-IC requires basically no additional circuitry and will allow you to use a resistor or more properly a shunt of very low resistance.
normally what one would do if they wanted upto 10A is use a 10 miliohm resistor and then put a 50v/v amplifier on that. There is a nice table on page 7 http://datasheets.maxim-ic.com/en/ds...2-MAX4372T.pdf Last edited by comphappy : 10-01-2009 at 13:15. |
#10
Brennan,
The chip to which you refer was not available at the time. The chip called for is easily scaled by one external resisitor to produce a usuable range for the input current we expected. Please note that this is a multichannel device intended to look at up to eight different current sense inputs and channel them for our use to the OI. We also developed this for a handheld unit which we then used to help teams troubleshoot problems. One of the first was the ThunderChickens which were using a multimotor transmission that year. It pointed out a dead motor in that system after team mentors had been scratching their heads for a while. For anyone trying to develop another method, please remember that there does not exist a bipolar power supply on the robot to which standard analog options can be connected. |
#12
Oh dont get me wrong what you did I am sure was great, I just cant read the schematic (too blurry). Things change with time, I know that the meters that I have made over the last eight years a very different. Keep up the good work.
#13
Note that they are good for 500% overload i.e. 250 amps. 50 amps is probably not enough range for all conditions. You could probably replace the 50 amp parts with the 200 amp allegro parts. That would enable you to measure currents near stall conditions. |
#14
All, thanks for the info. I'm glad to hear that I am not the only one that would consider the Phidgets current sensors "low impedance" and thus legal.
Al, I as well can't make out the details of the schematic but it's no big deal. It looks like the Phidgets devices are a COTS solution to our problem. Quote:
As long as they meet FIRST's idea of "low impedance" then I think they are legal. I'm not sure why we would ever need more than 50A. We can't have any motor on a breaker greater than 40A so why wouldn't 50A be enough. Same with the 20A and 30A Phidgets on 20A or 30A breakers. Please explain further if I am missing something. |
#15
The motors can draw a pretty big current spike under some conditions, without popping the breaker.
| Cheap Torque Measurement? | ChuckDickerson | Motors | 15 | 13-06-2005 13:57 |
| measurement problems? | jakk | General Forum | 2 | 16-01-2005 17:22 |
| Drill motor gear measurement | dmellich | Motors | 10 | 23-06-2004 12:03 |
| Current Sensor | Adam Shapiro | Electrical | 48 | 11-02-2004 07:06 |
| Actual execution time measurement | Dan | Technical Discussion | 5 | 24-03-2003 11:36 |
