Go to Post When you and your friend consider dressing up as a Potentiometer and “magic smoke” for Halloween! - BX MARK [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 09-01-2009, 15:57
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Buying extra Electronics
I've found sites to buy extra products (Jaguars, Wago connectors, etc) but can't seem to find a site for the Dongle. We need an extra or 2 just in case, but they are nowhere to be found. Help?
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
Unread 09-01-2009, 16:04
eitang eitang is offline
Hamosad 1657
AKA: Eitan Galon
FRC #1657 (Hamosad)
eitang has a spectacular aura abouteitang has a spectacular aura about
Re: Buying extra Electronics
if you mean the enable\disable switch:
from part 3 of the control system manual:
3.1.7 Competition Port Pinouts
The competition port is used to enable / disable the robot. A “dongle” is provided in the Kit of Parts
for teams to use for this purpose when not in a competition. If teams need to make a replacement
dongle or need additional spare dongles, a team-constructed dongle can be fashioned by
connecting pins 8 and 9 of the competition port to a switch. NOTE: it is essential that the other pins
© FIRST 2009 FRC Control System Manual: Section 3 – Component Datasheets, Rev 0.5 Page 8 of 38
of the connector be left unconnected, as some of the other pins contain power and/or ground –
accidentally shorting other pins of this connector can permanently damage the Driver Station.
An inexpensive dongle (shown in the photo below) can be fashioned out of components readily
available locally:
• PC Board Toggle Switch SPST
• D-Sub Connector 9 pin male
• D-Sub Connector Hood sized to fit
Unread 13-01-2009, 14:32
David G David G is offline
FRC #2518
David G is an unknown quantity at this point
I just built two for our team, here is the Radio Shack part numbers/cost:
275-0645 - $3
276-1427 - $2
276-1539 - $2
So for each dongle: $7 of parts, a little scrap wire and a little soldering. The first one took 25 minutes, second one took 10 minutes.
Unread 13-01-2009, 16:14
adengler's Avatar
adengler adengler is offline
Mr. Dengler
AKA: Aaron Dengler
FRC #2090 (Buffnblue)
Rookie Year: 2007
adengler will become famous soon enough
Thumbs up Re: Buying extra Electronics
Thanks for the post.
2090 BuffnBlue | Punahou School | Honolulu, HI
buying cylinders 1574aviad Pneumatics 1 07-02-2006 14:32
Buying Joysticks computer411 Control System 3 14-06-2005 12:44
Buying Servo Gamer930 Motors 4 13-02-2005 20:44
Buying IR sensors Atheist Electrical 2 16-02-2004 13:39
Question about buying electronics _GP_ General Forum 5 01-02-2004 12:43
