Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
  #16   Spotlight this post!
Unread 11-01-2009, 15:09
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: Chain Tensioner
If you have the resources to machine to close tolerances and you space your wheels by an integer number, you will not need tensioners until the chain stretches and then you can just replace it. I would personally not run without tensioners but it can be done. I would rather tension then replace but some teams are ok replacing chain more frequently for the weight savings.
Mentor 2415
  #17   Spotlight this post!
Unread 11-01-2009, 15:14
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Chain Tensioner
Assuming you have the capabilities to make either, it is simpler to make as well.
  #18   Spotlight this post!
Unread 11-01-2009, 18:42
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Rookie Year: 1999
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: Chain Tensioner
we are closing in on 11 months without replacing our chains on our 2008 robot. and not one problem. also as Adam stated it saved us from making all other tensioner associated parts. I predict the drive chains lasting at least 5 years on this year robot.
mike d
See Ya
  #19   Spotlight this post!
Unread 11-01-2009, 19:20
AKA: Sean
Re: Chain Tensioner
Wow that is incredible. So are the chains loose now? How did you figure out the spacing to get it so perfect?
Mentor 2415
  #20   Spotlight this post!
Unread 11-01-2009, 19:55
all hail Passmore
Rookie Year: 1999
Re: Chain Tensioner
they were loose to begin with and they are even more loose than when we started but with 180 degrees of wrap they are still working fine. as for the spacing, we use #25 chain so the axle spacing is just a dimension divisible by .250 or 1/4".
mike d
See Ya
  #21   Spotlight this post!
Unread 11-01-2009, 20:04
AKA: Sean
Re: Chain Tensioner
Thats what I thought you guys did. I guess since you weren't using a super high force drivetrain the shock load on the chain wasn't great enough to break it. I always thought the reason for chain tensioning on #25 chain was so that it stays taught and doesn't snap when a shock is introduced. This year would be perfect to try going without a tensioner since the forces are so low on the drivetrain.
Mentor 2415
  #22   Spotlight this post!
Unread 11-01-2009, 20:58
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
Rookie Year: 2007
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
Re: Chain Tensioner
Originally Posted by RoboGeek99 View Post
We were debating whether a floating tensioner (leaning to toward one manufactured by McMaster-Carr Model #5973K2) would work on a chain with a slight angle...we called the customer service and they didnt know so we wondered if anyone ever used on a chain path not parallel to the ground...if so how efective
Love, Peace, and Robot Grease
Team 2582 PantherBots
Last year we used a floating sprocket on our launcher. here's a pic.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
  #23   Spotlight this post!
Unread 12-01-2009, 20:33
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Re: Chain Tensioner
I used to get all the drive train components about where I wanted them, mount the chain, then drill the holes in the right places. No real precision is required, though a good eye helps. Don't over complicate things. It's only rocket science if your robot is chosen for the next mission. You can probably find several good books about chain drives on Google books that were published from 1890 to 1915 or so.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #24   Spotlight this post!
Unread 12-01-2009, 21:16
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Chain Tensioner
We made some UHMW & Ziptie chain tensioners which resembled those of Andymark. They were on 4 chains that were all at a 5-10 degree angle and they worked fine.
You can guarantee they'll work fine so long as the spacing between the chain through the tensioners is smaller than the diameter of your smallest sprocket. That may not be easy to do though.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
pic: Floating Zip Tie Chain Tensioner R.C. Extra Discussion 66 15-01-2009 15:53
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
