Go to Post Banned for being a nerd. There are no nerds in here! - Schnabel [more]
Unread 09-01-2009, 18:51
Lucario231's Avatar
Lucario231 Lucario231 is offline
FRC #0033 (Killer Bees)
Rookie Year: 2007
Lucario231 is an unknown quantity at this point
LabVIEW and robot problems
Hi
I have noticed an error or a lag in labview when it is communicating with the bot. When you flash the code to the bot then run it with low power to the motors eventually the robot starts clicking like ABS in car. Then it drives by its self. The solution I have found it that of power cycling the robot. Then it drives smoothly.
Has anyone else seen this while programing??
I have tried disconnected labview from viewing the data and i still find that problem.
Thanks in advance
First problems with FTC and Labview PhilBot National Instruments LabVIEW and Data Acquisition 0 10-09-2008 20:21
ROBOT C and the LabVIEW Dashboard robogeek753 Programming 5 20-02-2008 11:30
File Open Problems in LabVIEW pyroslev LabView and Data Acquisition 3 20-01-2007 15:52
LabView Dashboard Problems brummer_13 LabView and Data Acquisition 11 01-02-2006 20:13
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
