Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Unread 10-01-2009, 10:09
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Extra Motors?
Other than the 2 additional CIM's are you allowed any other motors that are not provided in the Kit of Parts?
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
Unread 10-01-2009, 10:18
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Extra Motors?
The rules section 8.3.7 Motors & Actuators tells what you can and cannot use...I'll let the rule book explain it....
http://usfirst.org/community/frc/content.aspx?id=452
Unread 11-01-2009, 19:54
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
Re: Extra Motors?
We have the same question. We intended to use 4 Banebot motors, but after reading the rules a little closer, it looks like this would not be allowed.
-Chip Tucker
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 11-01-2009, 20:52
MrForbes's Avatar
AKA: Jim
Re: Extra Motors?
That's how I undestand it too. The only additional motors are two CIMS, and however many small servos you want.
Unread 17-01-2009, 16:55
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Team Role: Mechanical
Rookie Year: 2007
Ozeaden is an unknown quantity at this point
Re: Extra Motors?
no what the rules say is that you can only use 4 of the cim and then after that you can do whatever you want. you can have 8 banebot and it wouldnt matter.
http://www.eaglerobotics.com/
Unread 17-01-2009, 17:00
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Extra Motors?
Please read <R52> and <R51> in that order. If you show up to competition with those 8 banebots motors, the first inspector will make you remove them. He'll be backed up by the other inspectors and the game manual.
Originally Posted by Section 8 of the Game Manual
<R52> Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R51>.
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
<R51> Motors specifically permitted on 2009 FRC ROBOTS include:
A. All motors, actuators, and servos provided in the 2009 Kit Of Parts,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the Kit Of Parts),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 17-01-2009, 17:08
Rookie Year: 2007
Re: Extra Motors?
ok didnt see the in addition to part. thanks for the info.
Unread 22-01-2009, 21:50
saverave saverave is offline
saverave
AKA: Cameron Reich
FRC #2531 (Robohawks)
Team Role: Student
saverave is an unknown quantity at this point
Question Re: Extra Motors?
So, this may seem redundant, if I understand you guys correctly, but...
we receive 2 globe motors, and are wondering if it is possible to use one more. Take in regard, we are not planning on using them for drive, but for "picking up" balls.
Unread 22-01-2009, 21:58
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Re: Extra Motors?
nope, not allowed sorry (read above posted rules)
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 22-01-2009, 21:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Extra Motors?
It doesn't matter what you want to use them for. You may use the motors that came in the KOP plus 2 CIMs and unlimited servos that meet the spec listed.
2 Globes came in the KOP so 2 Globes is what you are allowed to use.
Unread 23-01-2009, 09:00
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Extra Motors?
Also consider that you can use servos that are designed for continuous rotation as long as they comply with the max speed and torque specs in the manual. Not exactly high power output (Power = torque * rotational speed =100 rpm * 55 oz-in = 10.5 rad/sec * 0.39 Nm = 4.1 Watts) but it could be useful work.
http://www.acroname.com/robotics/par...-RO-SERVO.html
The above servo MAY be sufficient (I didn't find it's max speed at 6V spec).
This has not been made really clear to teams yet but if you use servos other than a Hitec HS-322HD or Vex servo, your inspector will probably ask to see a datasheet for confirming max speed and torque. Please bring datasheets or at least load them onto a computer for inspectors to check.
Russ
Unread 28-01-2009, 20:06
saverave
AKA: Cameron Reich
Team Role: Student
Re: Extra Motors?
I was just reading the manual, and according to <R50>, it states "Motors specifically permitted on 2009 FRC ROBOTS include:
E. COTS motors used as one-to-one replacements (i.e. identical vendor and part number) for motors, actuators and servos provided in the 2009 Kit Of Parts that may have failed or become inoperable."
Then, If you read <R51>, I realized that there is a typo.
<R51> Items specifically PROHIBITED from use on the ROBOT include:
B. Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not). The Underlined area should read "with the exception of those specifically permitted by Rule <R50>." Rule <R50> allows the use of Motors in the 2009 KoP, which include the motors I asked about earlier. Now, granted it is debatable, but it DOES seem to allow use of, unless that is the "or in addition to" part.
Unread 29-01-2009, 17:41
CHSRobotics CHSRobotics is offline
WogueRobotics
FRC #1751 (The Harbingers)
Rookie Year: 2007
CHSRobotics will become famous soon enough
Send a message via AIM to CHSRobotics
Re: Extra Motors?
So are we allowed to have 4 window motors??????
Unread 29-01-2009, 17:51
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: Extra Motors?
No. You are allowed as many window motors as came in the KOP.
<R52> reads in part: "Items specifically PROHIBITED from use on the ROBOT include:
A. Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R51>."
<R51> reads: "Motors specifically permitted on 2009 FRC ROBOTS include:
D. One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT."
I don't see window motors mentioned anywhere in <R51>. Do you?
Past teams:
  #15   Spotlight this post!
Unread 29-01-2009, 18:17
WogueRobotics
Rookie Year: 2007
Re: Extra Motors?
Okay, thank you for the answer. But next time, a simple "no" would have suffice?
Locating Extra Motors ilustrus Motors 0 13-01-2006 16:41
HELP!! Any extra Van Door motors??? Willing to trade =D archiver 2001 2 24-06-2002 03:04
HELP!! Any extra Van Door motors??? Willing to trade archiver 2001 5 24-06-2002 03:02
Extra Window Motors - trade for any others? archiver 2000 2 23-06-2002 23:04
Ordering Extra drill Motors mnkysp6353 Motors 1 30-09-2001 03:21
