Go to Post Honestly, no one at a FIRST competition is gonna judge you. Chances are, there are least 20 people dorkier than you. - JohnnyB [more]
Unread 10-01-2009, 11:40
foxdend296 foxdend296 is offline
FRC #0384
foxdend296 will become famous soon enough
Six or four wheels
Who has an opinion on wether to use six or four wheels . does putting more weight on four wheels work better than equal weight on six?? any help would be appreciated.
Unread 10-01-2009, 12:52
landon2345's Avatar
landon2345 landon2345 is offline
AKA: Landon
FRC #2345 (United Entropy)
Team Role: Electrical
landon2345 is an unknown quantity at this point
Re: Six or four wheels
Our team has been discussing this recently. At the moment we are considering a 4-wheel tank drive but may move to six. After looking over threads on this site I think that it may not make much of a difference. Friction is dependent upon force so putting more wheels divides the amount of force exerted by the robot due to gravity by the number of wheels. However, is there a difference between friction and traction? One of my teammates mentioned "dually?" trucks (pickups with four wheels on the back axle - two on each side). He was talking about how the increase in traction allowed it to pull more weight whereas a pickup with the same engine and only 2 wheels on the back axle would have its tires slip and would not be able to pull a heavy load.
Please note. I am still a noob.
Help? Any thoughts?
Unread 10-01-2009, 12:53
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Team Role: Leadership
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
This is already being discussed here. Please search before you post. Thanks!
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 10-01-2009, 13:02
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
here. Please search before you post. Thanks![/quote]
Starke,
The link you provided only discusses the physics of traction, while the OP is asking for a more general discussion.
To answer your original question, foxdend, there is no best solution for every team. Some teams will have greater access to technical mentors, machine shops, money for parts, etc., that will give them options that teams without these resources simply don't have. That said, here is my recommendation: unless you have *really* solid grounds to think that six wheels will provide a significant maneuverability advantage, stick to four. Adding two extra wheels (unnecessarily) complicates your drive train. First, with six wheels, keeping all the wheels level is an issue. Second, you have to decide which wheels to drive, and if it's all of them, that's yet more stuff to do for your drive train/chassis team. So short answer, stick to four wheels.
Best of luck this year,
Paul
[quote=Starke340;797569]This is already being discussed
Unread 10-01-2009, 13:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Trucks use dual wheels because each tire can only carry a limited amount of weight, and using two tires next to each other doubles the load capacity of the truck (assuming the axle, springs, etc are strong enough).
Unread 10-01-2009, 13:24
megaman_22201's Avatar
megaman_22201 megaman_22201 is offline
FRC #1778
Team Role: Mechanical
megaman_22201 is on a distinguished road
Smile Re: Six or four wheels
please everyone keep in mind that when you are making design decisions you take into account that in the game you will ALWAYS have a trailer attached to your robot in the matches.
this will add an extra 40 pounds to your robot AND an extra set of wheels.
hope this proves useful to the teams that read this ^_^
-Avinesh-
-Team 1778-
-----Avinesh-----
---Team__1778---
Are six wheels better than four? cziggy343 General Forum 36 10-01-2009 23:13
pic: Six Keepers jgannon Extra Discussion 19 23-07-2007 22:38
Rainbow Six 3 Alex Cormier Chit-Chat 3 14-03-2004 21:04
Why Six Weeks? Gabriel General Forum 20 22-02-2004 23:18
Six Flags? Hermione692 Championship Event 29 29-04-2003 21:12
