Go to Post "And we will transform our schools and colleges and universities to meet the demands of a new age. All this we can do. And all this we will do." - OScubed [more]
Unread 01-10-2009, 11:59 AM
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
Rookie Year: 2007
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
Problem deploying/running default code
We are using labview and completed the benchtop tests. We configured the router, bridge, and CRio successfully. Now we are attempting to upload the default labview project to the CRio and do not get any motor control from the driver station. We can connect to the CRio in the project window so I do not believe it is network related, rather how we are running/uploading code. Could someone explain what we are possibly doing wrong and how to fix it.
***RESOLVED*** Anyone with this problem try reflashing the firmware on the driver station. It worked for us.
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
PWM Problem with Default Code kbregler Programming 16 02-03-2007 03:14 PM
Default code problem capenga Programming 8 02-01-2005 08:09 AM
problem with the default code MarkVH Programming 7 01-28-2005 12:04 AM
Problem running compiled code jskene Programming 10 01-23-2005 09:13 PM
Problem with FRC Default code AsimC Programming 2 01-11-2004 07:22 PM
