Go to Post If you don't like contact, your robot is not built well enough. - sanddrag [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 10-01-2009, 12:50
HHS Tigerbots HHS Tigerbots is offline
FRC #2509
HHS Tigerbots is an unknown quantity at this point
2009 AM Kit bot frame parts for ProE?
Has anyone found the new 3D models of the Kit bot chassis, corner connects, c-channel?
Thanks
Unread 15-01-2009, 20:27
jhouser's Avatar
jhouser jhouser is offline
MCAD $@#$@#$@#$@#$@#., Pelco
FRC #1671 (Team 1671)
jhouser will become famous soon enough
Re: 2009 AM Kit bot frame parts for ProE?
Yes, those files are availabe via STEP files from the Andy Mark website.
Long
http://lib.store.yahoo.net/lib/yhst-...e-Assembly.stp
Short
http://lib.store.yahoo.net/lib/yhst-...embly-Wide.stp
Unread 19-01-2009, 22:12
PTC_FRC PTC_FRC is offline
PTC_FRC is on a distinguished road
Hi all,
The desired components have been uploaded to the PTC Kit Of Parts.
www.ptc.com/go/firstkop
Specifically, they can be found in the following folder.
http://www.catalogds.com/db/service?...egory=AM_Ki t
Look for c_base_assembly_wide and c_base_assembly
There are two pages of results for this folder, click the result page pull-down and select 2 for the rest of the results.
Hope that helps.
mark
2009 FRC Kit of Parts (Pro/ENGINEER format) - Supported by PTC PTC_FRC CAD 18 18-11-2009 01:02
**FIRST EMAIL**/2009 Kit of Parts Now Available in Autodesk Inventor and Design Comp. Mark McLeod FIRST E-Mail Blast Archive 1 06-01-2009 08:16
**FIRST EMAIL**/2009 FRC Kit of Parts Modeled and Available Now Through PTC's CAD Lib Mark McLeod FIRST E-Mail Blast Archive 0 03-01-2009 12:30
Kit of Parts Frame Xufer Technical Discussion 22 12-01-2005 17:08
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
