Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 10-01-2009, 15:17
jescholler jescholler is offline
FRC #0093
jescholler is an unknown quantity at this point
MaxBotix LV-MaxSonar-EZ4
I tried testing the MaxBotix LV-MaxSonar-EZ4 sensor from SparkFun. I was using the analog output and the waveform varied from near 0V to approximately 1V like a square wave. The pulse width was not constant. I'm not concerned with what the voltage level was on the high side, but as far as I understand, the analog voltage should be fairly constant.
I tried implementing the filter (100k resistor and 0.1uF capacitor) that MaxBotix recommends on their FAQ, but that only rounded the edges of the squar wave.
In case you were wondering, I am positive that I'm connected to the analog output and not the PW output.
Has anyone had this problem with this series of sensors, and if so, what did you do to fix it?
Unread 10-01-2009, 17:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: MaxBotix LV-MaxSonar-EZ4
Are you sure you're positive? because that really, really sounds like the PWM output. Just for giggles, check the other outputs, see what they look like, and tell us what you find, OK?
Unread 13-01-2009, 22:09
FRC #0093
I'm sure that I'm positive. The fist thing I thought was that it looks a lot like a PWM signal. The only difference is it doesn't swing rail to rail.
We're ordering a new one, so we'll know if it was defective or damaged.
Unread 13-01-2009, 22:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I believe you when you say you're certain you're connecting to the analog out. But are you as certain that you have the power connections correct?
Unread 20-01-2009, 14:17
ScottW of MaxBo ScottW of MaxBo is offline
ScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of lightScottW of MaxBo is a glorious beacon of light
Dear jescholler,
We have reviewed your problem and would be glad to replace your sensor. We are not sure what is causing this anomaly but would be glad to replace your sensor and then test the bad one.
Please email me with your shipping information and we will give you all the details.
I look forward to your email.
Best regards,
Scott Wielenberg
Technical Support & Sales
of MaxBotix Inc.
Phone: (218) 764-2489 Ext. 2
Fax: (218) 764-2194
Email: scott@maxbotix.com
Web: www.maxbotix.com
Best regards,
Scott Wielenberg
of MaxBotix Inc.
Fax: (218) 764-2194
Mounting Maxbotix rangefinders pogenwurst Sensors 7 06-07-2008 22:09
Maxbotix Ultrasonic Sensor Help... manderson5192 Programming 9 22-02-2008 14:25
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
LV-MaxSonar-EZ1 marccenter Programming 2 06-02-2007 19:25
Maxbotix Sonar Sensor DonRotolo Electrical 17 04-02-2007 12:27
