Go to Post As my boy Macklemore once said, "The greats weren't great because at birth they could paint, the greats were great because they paint a lot". - Andrew_L [more]
Unread 10-01-2009, 17:06
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
Switch to OI
does anyone know how to wire a basic toggle switch to the OI board? I'm not even sure if it's possible, but if it is and someone knows how to do it that would be sweet. also if someone knows how you can do it without a resistor that would be helpful. I found the thread kind of about this, but it was from a different season without the new system. heres a picture of the toggle I'm trying to wire, left pin is ground, ACC in the middle, and theres a + on the right pin.
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 10-01-2009, 17:08
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Switch to OI
My suggestion is to wire the switch between one of the Digital Input pins on the side and ground. Your cRio can then read the status of that pin and behave accordingly.
For details on the pins on the side of the OI, see the OI documentation please.
Don
Unread 10-01-2009, 23:09
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Switch to OI
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf Page 4
Wire the + to the 5V, wire Vcc to ground, wire the other pin to signal.
When it's off, Vcc and signal will be connected, which pulls the value to 0 and will be a false in the code.
When it's on, + and signal will be connected, which makes value 5V and will be a true in the code.
The "resistor" you might have heard of is often including in the innards of the OI. This year's DS does not have one, so all three pins are used (and thus you shouldn't use 2 pin switches on the DS). You can learn about why here: http://en.wikipedia.org/wiki/Pull-down_resistor
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
toggle switch Windward Programming 31 27-01-2006 22:38
Switch BillyJ Programming 1 13-04-2005 16:39
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
