Go to Post Well, it worked in inventor . . . - Chris Fultz [more]
Unread 10-01-2009, 17:28
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
8.2.1 <R6> Question
The ROVER WHEELS must
be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground,
with the axis of rotation parallel to the ground and penetrating the wheel hub).
Does this mean that our wheels have to be parallel to the sides of our robot or the other wheel? That would fall under normal orientation? we were thinking about angeling our wheels so that there not parallel with each other
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 10-01-2009, 17:54
Hugo304 Hugo304 is offline
FRC #1577
Hugo304 is an unknown quantity at this point
Re: 8.2.1 <R6> Question
I think the rule says that you have to put the wheels vertical to the floor, and it doesnt have to be parallel to the sides of your robot or the other wheel.
thats what i understood from this rule if i'm wrong tell me...
Unread 10-01-2009, 18:38
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
Rookie Year: 2000
Hugo is correct. Another way of putting it, the axle through your wheel must be parallel to the floor. It can be twisted in any orientation with respect to your robot frame.
(since 2004)
Unread 10-01-2009, 18:42
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
This rule explains why some teams are deciding on using crab drive this year, all of the wheels, all of the time are facing the same direction.
Unread 10-01-2009, 20:23
AKA: Brandon Liatys
Rookie Year: 2007
what exactly is crab drive? I never heard of it....
Unread 10-01-2009, 20:39
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
http://www.youtube.com/watch?v=EFXimlx1iOU
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 10-01-2009, 20:40
AKA: Brandon Liatys
Rookie Year: 2007
now thats interesting. thanks!
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
