Go to Post Our prototypes are good and running, now just need to do some magic to transform all that wood to aluminum. :eek: - FIRSTMa2104 [more]
  #16   Spotlight this post!
Unread 11-01-2009, 18:50
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
Team Role: Leadership
Rookie Year: 2007
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Re: Going "wide" with the chassis
Originally Posted by PhilBot View Post
Here is a video of our wide robot test:
http://www.youtube.com/watch?v=UMXqbfWOj5o
seems like it works quite well...
Tmr i want to get the frame built in wide config, and then compare using 2 toughboxes and having 2 free driving wheels to having a tough box on each of the 4 wheels...
Have you guys tested that?
  #17   Spotlight this post!
Unread 11-01-2009, 18:59
Great to see others getting the same results. Wish you guys the best of luck this year in Chesapeake =)
Originally Posted by Daniel885 View Post
Con: Increases chance of collision and jams.
Hmm, I see your point but not quite. Care to explain further?
  #18   Spotlight this post!
Unread 11-01-2009, 19:01
dudefromjapan dudefromjapan is offline
Driver/Electrical Team
FRC #2496 (Team TruBlu)
Team Role: Electrical
Rookie Year: 2007
dudefromjapan is on a distinguished road
By the looks of the video, the robot was tested with a tough box on each of the wheels and handles quite well. From my teams experience, have 2 free driving wheels and steering with 2 powered wheels was quite hard and takes a while to turn. This could be because we haven't used software to limit the power output on our motors yet, but it's information nonetheless
  #19   Spotlight this post!
Unread 11-01-2009, 19:02
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
We decided to mount our wheels in the wide position
Pro: Even with the wheels and slippery surfaces it is still easy for even rookies to control.
Pro: Ball capture is not difficult
I think the meaning was that with a wide base you wouldn't be able to fit through as narrow of places as you would with a long base. Which is a good point but in this game with the trailer the wide base makes it so that your overall length with the trailer is decreased which I would say is a fair trade off.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #20   Spotlight this post!
Unread 11-01-2009, 19:04
Re: Goig "wide" with the chassis
DO NOT HAVE NULL WHEELS THIS YEAR.
This has been repeated frequently in many threads. Have all wheels powered otherwise they are useless and add dead weight.
A toughbox on each wheel does work well. Just make sure if you use it on a final robot that your toughboxes have washers keeping the keys in and that they are lightened. Replace the clear backing with Al and add lightening patterns all around. Also the side plates don't need to be there, might want to just add in some delrin standoffs instead. Hope that helps.
  #21   Spotlight this post!
Unread 11-01-2009, 20:35
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Team Role: Coach
Rookie Year: 2000
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
Glad I started this thread: will help us and other teams
deciding wich way to go. Now, watching 1629 video, from
my calculations, their top speed schould be somewhere
around 10.5 fps. For some reason they going much slower.
  #22   Spotlight this post!
Unread 11-01-2009, 20:43
They're capped.
By our calculations, anywhere from 8-15fps is going to be good for this game. I personally like the 9.5-11.5-13fps range.
  #23   Spotlight this post!
Unread 11-01-2009, 20:57
Team Role: Coach
Rookie Year: 2000
With the AM box(12.75:1) and 6" wheel direct drive
your top speed is around 10fps. Correct me if I'm wrong.
  #24   Spotlight this post!
Unread 11-01-2009, 21:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
A trick we used last year was to remove one stage of gear reduction in the Toughbox, changing the ratio to 3.57 or thereabouts. It's pretty easy to do, and not easy to spot in a video of someone else's robot.
  #25   Spotlight this post!
Unread 11-01-2009, 21:23
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Rookie Year: 2007
Booksy will become famous soon enoughBooksy will become famous soon enough
Many thanks. I plan on using this to talk my team out of a crab drive.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
  #26   Spotlight this post!
Unread 11-01-2009, 21:33
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Glad I started this thread: will help us and other teams deciding wich way to go. Now, watching 1629 video, from
I doubt that we're going that much slower, although we were playing with the joystick sensitivity througout the day.
Once you try this yourself you'll see that it's not about how fast the wheels can go, but how smoothly you can accelerate and decelerate. Gunning it just makes the wheels spin. It takes a steady hand (and hopefully some good software) to stay controlled. Once the drivers got the hang of steady starts, then the trick was stopping without skidding. There's no letting the stick go, or pulling backwards. The driver needs to allow time and space to slow down under power.
The Trailer actually aided turning by performing a jackknife procedure.
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
  #27   Spotlight this post!
Unread 13-01-2009, 14:24
AKA: Dani
Rookie Year: 2007
so assume you use 4 cim motors for each wheel...
say you then wanted to have a belt drive system.. what motors could we use to drive that. My team seems to think that any other motors except the cim motors are too slow...
any ideas?
  #28   Spotlight this post!
Unread 13-01-2009, 14:49
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Doubling up on fisher prices should suffice.
  #29   Spotlight this post!
Unread 13-01-2009, 14:56
AKA: Dani
Rookie Year: 2007
hmm ok we can look at that
  #30   Spotlight this post!
Unread 13-01-2009, 15:54
Hannah1405's Avatar
Hannah1405 Hannah1405 is offline
1405 'til I die
None #1405 (Falcons Robotics)
Rookie Year: 2007
Hannah1405 is on a distinguished road
Send a message via AIM to Hannah1405
We were thinking of going wide with our chassi, but were concerned that it would be really hard to get out of any tight squeezes, or make any tight turns. However, we are excited to make a mock up of it, and test it. I just wish they had sent a sample of the floor!
Falcons Robotics
"60% of the time, it works every time."
Pitfalls of having a "wide" robot? wilsonmw04 Technical Discussion 9 22-01-2008 13:01
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
