Go to Post Although it is tempting, try not to toot your own horn in this thread. While you may have an awesome bot, the real compliment should come from other teams. - Andy Baker [more]
Unread 11-01-2009, 01:49
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Rookie Year: 2007
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Poly Cord / rubber roller tubes?
Hey,
So i know it as poly cord, but im not sure if that is the correct name. It is colorful plastic cord about 1/4 dia. I know a bunch of teams used this in 2006 (ie 1114 and 111) to transport balls. My team hasnt ever used it but I would like some input on good sources to order from.
Also I'm pretty sure it can be bought in pre-determined lengths (already in a loop) or in a spool where you connect the two ends. My team is debating over which is better or even if these are two options. I'd love some feed back from teams that have used this stuff in the past. Maybe links to good places to find it.
Thanks in advance
Mens et Manus
[FTC]: Lego Motor Extension Cord? ttldomination FIRST Tech Challenge 2 11-01-2009 11:52
New Team to be (Possibly) Started at Cal Poly Pomona A. Leese Starting New Teams 13 10-03-2005 01:51
Gum Rubber Brawler006 Technical Discussion 8 12-02-2004 07:57
sheet rubber Adams High Man OCCRA 1 20-10-2002 10:07
Rubber Treads Anyone? archiver 2000 10 24-06-2002 00:29
