Go to Post It's in the RUMOR MILL section, hence it is a RUMOR. Personally I find it entertaining to see what gets started in this particular forum section and have people go off the deep end. - Gary Dillard [more]
Unread 11-01-2009, 09:13
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Run Kernel Task w/o reboot
Can you D/R KT(debug/run Kernel task), and then modify the code, build, and then D/R KT again, WITHOUT rebooting the cRIO to stop the task?
Unread 11-01-2009, 09:25
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Run Kernel Task w/o reboot
Yes. Go to the Remote Systems window, right click on your program in the cRIO and delete it. There is code in the latest update that will kill all the tasks spawned by your program so it exists cleanly.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 11-01-2009, 11:31
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
And by this, he means search for (typically) YourProject.out and delete that.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 11-01-2009, 14:34
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
Team Role: Leadership
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
You can see your program running in the debug window (the one above th break points) right click the top level and select terminate or terminate all. If you get a kernel crash from one of your programs you may want to reboot as reminates may get left behind, we wasted a long time on that.
A2D Solving the Imaginary Error Function...
Unread 12-01-2009, 12:08
AKA: Brad
Thanks for the clarification!
There is code in the library that is designed to cleanup properly when the main task is terminated. But the cRIO has no memory protection. So it is possible for a program with memory and pointer bugs to write all over anything else in the cRIO and cause it to be unstable. In those cases rebooting will guarantee that the new program run will work more correctly.
Brad Miller
What is the hardest (yet possible) task in this year's game? Wayne C. General Forum 88 16-01-2008 18:30
I really need some help with this CSS task. Michael Hill Website Design/Showcase 3 30-07-2006 18:18
Auto run sirbleedsalot Chit-Chat 3 06-02-2005 00:17
A new season, a new task Koko Ed Fantasy FIRST 18 19-12-2004 13:21
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
