Making belt loops with vinyl tubing
Our team is trying to make belt loops out of vinyl tubing. Anybody know the most secure way connecting the ends of the tubing? Thanks in advance
Re: Making belt loops with vinyl tubing
I'm no expert on the subject but you should be able to take the ends of the tubes and melt them together with a heat gun or soldering iron. If you could post up the link or a picture of the product you might get more answers.
That would help- I'm having some trouble visualizing.
![]() I tried the melting technique thefro526 proposed. It worked quite well. Anybody else have ideas as well? Last edited by dudefromjapan : 11-01-2009 at 17:41. Reason: Image used before was HUGE XD |
Mcmaster says that there are two ways to do it. One is to melt the ends together by cutting a 45˚ angle such that you have a large surface area to combine. Just make the ends soft and melted with a heat source. (heat gun, soldering iron, lighter, torch etc) then combine using a scrap piece of angle as a guide for straightness. Or you can cut it without an angle and buy these barbed sticks which you insert into both. search "multi-barbed tube fittings " on Mcmaster.com
Do a search on Mcmaster for hollow tube round belting, they use a simple gromet and holds the material together very well. We've used them in the pass without a problem. Just cut to lenght and press them together.
Thanks for the useful input. I'll be looking into these solutions soon.
| Code error with while loops?? | Lakeeffect1674 | Programming | 6 | 09-03-2008 13:19 |
| Fun with Bosch Tubing | computerboi1503 | Chit-Chat | 1 | 09-02-2008 19:33 |
| Possible to do multi-speed transmission with v-belt? | Squirrelrock | Motors | 15 | 13-12-2005 14:44 |
| problems with pneumatic tubing in telescoping arm | johnnymac4545 | Pneumatics | 5 | 25-02-2005 11:19 |
| Making money with your site | Sam Oldak | Website Design/Showcase | 11 | 31-03-2004 10:03 |
