Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 11-01-2009, 17:28
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
More friction questions
We did a few rover wheel robot tests today and based on what I saw I am puzzled. It appeared that a lighter robot would accelerate faster then a heavy robot. Lets see if I can throw out some formulas
Heavier
533.8 N (120 lbs) (54.47 kg on earth) robot
Ff= µ • Fn
x = .05 • 533.8
x= 26.69 N
a=F/m
.4899 m/s^2 = 26.69 N / 54.47 kg
Lighter
400.3 N (90 lbs) (40.82 kg on earth) robot
Ff= µ • Fn
x = .05 • 400.3
x= 20.02 N
a=F/m
.4904 m/s^2 = 20.02 N / 40.82 kg
In standard units, the lighter robot will accelerate 0.0164 ft/s^2 faster.
Based on these numbers, unless I did something wrong, a lighter robot would accelerate faster on regolith then a heavier one (admittedly a small difference). So teams that are talking about adding weights to their robot to add friction should reconsider.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 11-01-2009, 17:38
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
Team Role: Coach
Rookie Year: 2007
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: More friction questions
Heavier
Ff= µ • Fn
x = .05 • 533.8
x= 26.69 N
a=F/m
Lighter
40.82 * 9.8 = 400.03
to 4 digits this rounds to 400.0 not 400.3
Unread 11-01-2009, 17:43
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
Team Role: Leadership
Rookie Year: 2007
m^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant future
Don't forget the trailer! More robot weight would reduce the relative effect of the trailer, yes?
Unread 11-01-2009, 17:53
Woody1458's Avatar
AKA: Woody Jansen
I actually got this number by converting 90 lbs directly into Newtons, as they both measure force.
GO DANVILLANS!!
Unread 11-01-2009, 18:04
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Yeah, I feel like this is more important.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 11-01-2009, 18:08
Matt times Matt times is offline
FRC #2585
Matt times is an unknown quantity at this point
another thing to consider is that if your robot skids out due to less fricitonal force because of the reduced weight (Force friction = mg x coefficient of friction) you have to use the coefficient of kinetic friction in the equasion which is less than the coefficient of static friction used when the robot is rolling.
Unread 11-01-2009, 18:10
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
It makes perfect sense to me. Think of 2 cars with equal power rolling at ten miles an hour. One car is 500lbs heavier than the other. The lighter car will accelerate faster with the same power because it takes less energy to accelerate.
When you actually observed this difference in acceleration were both robots moving or were they stationary? Traction doesn't have as great of an effect once your moving beyond a certain speed. If they were stationary the heavier robot should accelerate faster to a point because it's wheels are spinning less but the lighter robot should overtake it once it gets traction. (think drag racing)
This is a point I keep bring up with my team. I think it's better to design to be lighter and then be able to add weight for traction than to design heavier and be stuck with it.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 11-01-2009, 18:11
Woody1458's Avatar
AKA: Woody Jansen
Right but I'm proposing is the momentum of a light bot will be easily controlled by the friction of the wheels, even if that friction is less. So a heavy bot will be less willing to slow down based on the friction then a heavy bot. The change in friction shouldn't change anything because both robots encounter the same change.
GO DANVILLANS!!
Unread 11-01-2009, 18:16
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes. The mass of the robot and trailer need to be accelerated, but only the weight of the robot and a little bit of the trailer adds to the tractive force from the driving wheels.
Unread 11-01-2009, 18:22
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
Rookie Year: 2007
Well a lighter robot will have less frictional force but also have less inertia... so I think the effect cancels out. As far as the car analogy, we are limited by friction, not power (did you see 2 vs 4 motor test on kickoff?). Therefore teams should shoot for 120 lbs since it reduces the relative effect of the trailer and other robots. Along with that the cg should be towards the rear wheels to help turn with the trailer.
Unread 11-01-2009, 18:28
Woody1458's Avatar
AKA: Woody Jansen
As Mark Leon would put it "This is why we do the math". You brain can convince you anything makes sense, do the math to find out.
GO DANVILLANS!!
Unread 11-01-2009, 18:48
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
Rookie Year: 2007
I'm sorry... did you mean you experimentally tested and the lighter robot accelerated faster? The difference in the equations is due to conversion/rounding errors (try it with just 50 kg and 40 kg), but perhaps there's a factor we're not accounting for. For example, it takes less power to spin the wheels on a lighter robot.
Unread 11-01-2009, 18:57
Woody1458's Avatar
AKA: Woody Jansen
I was saying that basing ideas off what you believe will happen rarely works in my experience, especially concerning physics. I did no scientific method testing, but noticed some odd responses from playing with the robot and did the math behind it. And I would love for someone else to try the same thing, after all nothing is sure until its repeatable.
PS Once you move into dynamic friction (slipping wheels) it does not matter how fast your wheels are spinning you get the same force response.
GO DANVILLANS!!
Unread 11-01-2009, 19:10
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
Rookie Year: 2007
You're right, I probably shouldn't jump to conclusions so quickly. On Monday I'll experiment with different weights on our test chassis. We're also assuming the wheels and this surface follow the formulas perfectly.
As far as dynamic friction, I know you get the same force, but I was suggesting control implications since it would take less movement of the joystick to make the wheels spin.
  #15   Spotlight this post!
Unread 11-01-2009, 20:47
BigWhiteYeti's Avatar
BigWhiteYeti BigWhiteYeti is offline
FIRST class flier
AKA: Patrick M.
FRC #0857 (Superior Roboworks)
Team Role: Driver
BigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura about
Work with just the variables and see that weight makes no difference in acceleration:
Ff=uFn
Fn=9.8m
Ff=9.8um
Fnet=ma
Ignoring air resistance, Ff=Fnet
Ff=ma=9.8um
9.8u=a
u=.05
a~.5 m/s/s, no matter the mass of the bot.
-you're fired
More questions.. Magnechu Pneumatics 1 06-02-2008 16:38
More Power Distribution Block Questions TERTOLA Electrical 9 27-01-2008 18:17
More questions about Dewalt transmissions AJ R Technical Discussion 3 15-01-2007 17:38
more on friction maxgebhardt Technical Discussion 0 15-01-2003 19:23
More Questions... Lake Orion OCCRA 0 30-11-2001 19:27
