Go to Post Just think of the deadline as your six week deadline for FIRST, just when you think you can't do it, you are amazed by what you can do. - JackN [more]
Unread 11-01-2009, 20:09
newbee newbee is offline
None #0211
newbee is an unknown quantity at this point
Friction drives
I'm looking for clarification. If I use a friction wheel to drive the surface of wheels provided in the kit, there is a possibility that the friction wheels will somehow change the characteristics of the regulite wheels themselves. Is this grounds for disqualification?
Unread 11-01-2009, 20:15
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Re: Friction drives
So, if I understand you want to put a traction wheel on top of a rover wheel in order to power it, making the shape of an 8. I would not consider this to be illegal. But I am perplexed as to why would do this over attaching a chain.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
Unread 11-01-2009, 20:18
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
Team Role: Mechanical
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Re: Friction drives
One of the rules in the manual states that only the wheel can contact the floor and that wheel needs to be as close to "out of the box condition as possible". As long as the high traction wheel doesnt touch the floor, i think your ok. A little more detail in your intent would help....
Unread 11-01-2009, 20:20
Billfred's Avatar
Billfred Billfred is offline
Re: Friction drives
I quote part of <R06>:
The surface tread of the ROVER WHEELS may not be modified except
through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads,
alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive
materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER
WHEELS be used in as close to their “out of the box” condition as possible, to provide the
intended low-friction dynamic performance during the game
There's no definite answer on this one--if your drive mechanism left residue or exceptional wear on the wheels that altered its characteristics appreciably, particularly towards the direction of a higher coefficient of friction, other teams would definitely have grounds to approach the inspectors about it. Don't leave yourself open to it--test it, have the data ready if anyone asks, and be ready to switch to something else if it doesn't pan out for you.
Unread 11-01-2009, 20:22
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: Friction drives
I would imagine the ruling would depend on the sort of "friction wheel" you are using. If this wheel was made of sand paper (or some other really rough surface), I'd bet all eight of our orbit balls that the inspector would have a problem with it.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 11-01-2009, 20:32
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
Team Role: Teacher
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Friction drives
the only way i could see this giving you more traction is if the wheels that that gave power to the kit wheel were to wear so that rubber/urethane dust would rub on to the wheels and floor thus acting like sand on train tracks
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Drives in general Gamerboyb1 Technical Discussion 26 12-11-2007 19:28
holonomic drives Max Lobovsky Technical Discussion 5 10-03-2004 21:31
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
