12.75:1 enough?
Okay, I was working with some numbers and this is what I came up with for a 2 CIM drive (1 driving each side of the robot).
Torque supplied by 1 CIM at peak efficiency = 0.48 N m = 4.25 lbf in. Torque supplied by 2 CIMs = 4.25 * 2 = 8.5 lbf in. Max. Frictional Force = [150 lbf (robot) + 40 lbf (trailer)] * 0.2 (rounding the COF up quite a bit) = 38 lbf. Max. Torque = 38 lbf * 3 in (wheel radius) = 114 lbf in. Torque needed/Torque provided = 114/8.5 = 13.4. A toughbox provides a 12.75:1 reduction. Does anyone think that this will be sufficient for powering a robot? |
Re: 12.75:1 enough?
The maximum frictional force is not 150lbs + 40lbs. The trailer wheels are not powered and so don't add to your maximum tractive force. The tongue weight, however, will help you - let's call it 10 lbs (probably an overestimate). So your downforce is 160lbs.
This means that the maximum tractive force (with 0.2 CoF) is .2*160lbs = 32 lbf. Max torque = 32lbf * 3in = 96 lbf*in Torque needed/torque provided = 96/8.5 = 11.3 And realistically the CoF is 0.1 or below, so I think direct drive off the ToughBoxes provides more than enough torque (with 1 motor per side). |
Re: 12.75:1 enough?
Retired Starman built a competition type trailer and measured the weight (35 lbs), and the tongue weight (5 lbs).
Re: 12.75:1 enough?
50% Stall torque = 2 x 21.5 lbf-in x 50% x 12.75 = 275 lbf-in. 25% Stall torque = 2 x 21.5 lbf-in x 25% x 12.75 = 137 lbf-in. So I think a 2 CIM drive with the stock transmissions and a 1:1 sprocket ratio will work out just fine. Especially as you won't be getting the full 40 lbs out of the trailer, and the CoF isn't .2 |
Re: 12.75:1 enough?
I was thinking more of a 8-9:1 Ratio with one motor per side. But thatz just me.
| Is 12 hours enough? | Heretic121 | Technical Discussion | 15 | 29-03-2006 09:28 |
| pic: Close enough? | S.Nickens | Robot Showcase | 11 | 12-02-2005 00:34 |
| Is PBasic enough or not | punarhero | Programming | 2 | 05-03-2004 07:59 |
| Enough with the bumpers! | archiver | 2000 | 2 | 23-06-2002 22:32 |
| Enough already... | Gui Cavalcanti | Rules/Strategy | 3 | 08-04-2002 09:35 |
