Go to Post I think it's great the way people involved in FIRST always try so hard not to argue. It's a good sign that all the talk of Gracious Professionalism is working. - BaldwinNYRookie [more]
Unread 01-12-2009, 11:49 AM
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
cRio losing connection when "run as startup"
I am trying to create a Stand-Alone application and the cRio is losing communications.
I am able to run Robot main within Labview to test the code and confirm that the robot is responding correctly. I then build the applicaton. After building, it I run deploy or "Run as Startup" from the drop-down menu I recieve the Lost Communicatons with the cRio dialog and the applications stops deploying.
I had previously been able to deploy an application as startup.
Is there something I need to check to make sure the communications are correct for the build. The laptop's IP is 10.10.94.6 (team 1094). What changes would need to be done to connect the PC directly to the cRio so that the wireless communications are taken out the equation.
Any help would be appreciated
Team 1261 - cRIO on 2008 "Longshot" Tanner Robot Showcase 2 12-31-2008 12:44 PM
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 12-20-2008 10:14 PM
Will 3ds Max 2009 run on "regular" Windows XP? Kevin Thorp 3D Animation and Competition 3 11-12-2008 10:07 PM
when are "official" results due online? Brandon Martus Regional Competitions 3 03-09-2003 08:15 AM
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 06-24-2002 12:54 AM
