Sensor Board Programming
I just need to know if I can change the state of the Digital Out pins to send no voltage until the trigger button is Pressed
Re: Sensor Board Programming
What "Sensor Board" are you referring to?
When you say "no voltage", do you mean "0 volts" or do you mean "disconnected/high impedance"? I assume you are talking about using a joystick trigger to control a digital output, but the post title "Sensor Board" makes me unsure what digital output you want to use. |
| IR SENSOR BOARD | SuperSexcGuy | Electrical | 7 | 06-02-2008 09:24 |
| Wiring the IR sensor board | govvijay | Programming | 9 | 05-02-2008 19:41 |
| ir sensor Board ?????????????????????? | RRA4LIFE2 | Programming | 12 | 31-01-2008 23:16 |
| Hooking up the IR sensor board | chattycat14 | Programming | 0 | 30-01-2008 15:57 |
| Making a Sensor Board | SpaceOsc | Technical Discussion | 11 | 15-05-2004 12:46 |
