Go to Post What can fix anything?.... DUCT TAPE! - Mr.Twister [more]
Unread 12-01-2009, 14:17
LinuxMercedes LinuxMercedes is offline
Real men use Macs
FRC #1444 (Lightning Lancers)
LinuxMercedes is an unknown quantity at this point
Problem uploading code from a VM
I have a Mac running an XP virtual machine (under VirtualBox, FWIW) which I use for my development. However, I've been unable to deploy code from WindRiver to the cRIO from this machine. I set the file to deploy, click deploy, and it shows a progress dialog which says something like Downloading Code...(Waiting). I've let it sit like this for a few minutes, but to no avail. I know it works because our programming mentor's Dell downloads the same code right away.
Also, I can debug code on my machine just fine. Everything seems to work but the deploy button...
Any ideas? Or am I just limited to having to use a real machine to download code?
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
Uploading Old Code G1279 Programming 1 12-01-2008 22:35
Problem with program uploading 1573 Programming 49 28-01-2007 13:51
HELP needed, problem with streamling, need uploading space or diffrent solution... Nimmy General Forum 5 15-02-2006 11:18
Code problem iBob Website Design/Showcase 3 17-01-2004 14:14
