Game options
so my team is in turmoil right now. the rules say that nothing can exeed the perimeter of our bumpers. if this is so how can we pick up a ball or design something like that?
Re: Game options
Or your Payload Specialist can always load a top mounted hopper on your robot so you don't even have to pick any balls up off the floor if you don't want to. Check out some of the recent pictures here in the galleries on the portal page, & you'll see some ideas & concepts of those 2 ideas. Keep in mind other rules are in place to design around, but the key is that you are correct; nothing can extend past that bumper perimeter so no arms reaching out of your bot to grab things! Good luck! |
Re: Game options
Keep in mind that the bumper perimeter is defined as "the polygon defined by the outer-most set ofexterior vertices on the ROBOT". Along with the other bumper rules (which you should read and fully comprehend!), this means you can have gaps that allow balls to enter inside your bumper perimeter, then use whatever mechanism you design there to manipulate the ball. |
| Build Options | Gary Bonner | Programming | 3 | 24-03-2006 01:05 |
| CNC Options? | Andrew Blair | Technical Discussion | 5 | 06-02-2006 18:12 |
| A Webmaster's Options | JohnC | Website Design/Showcase | 8 | 28-03-2005 21:13 |
| Admin Options | srawls | CD Forum Support | 7 | 16-05-2003 18:18 |
| Options! | Brandon Martus | Announcements | 0 | 15-04-2002 13:08 |
