Go to Post The competition is about MUCH more than just the robot. If kids are glued to the robot all of the time, then they miss the rest of it... the other fun stuff, what makes FIRST, FIRST. - Kims Robot [more]
Unread 12-01-2009, 16:39
Mr-Shutter's Avatar
Mr-Shutter Mr-Shutter is offline
Audiophile
AKA: David
FRC #0612 (Chantilly Robotics)
Rookie Year: 2007
Mr-Shutter will become famous soon enough
Send a message via AIM to Mr-Shutter
Driver Station Login
Looking at the serial port of the DS to see if i can browse the /dev/ folder and see how my usb devices mount and out of curiosity. Problem is there is a login as always with linux. Anyone know the login? There is no reson we can't use other benifets of linux, including writing our own driver and building our own kernel right? :3
I see in logic, Black and White
Unread 12-01-2009, 23:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Driver Station Login
There indeed is a good reason not to let teams meddle with the programming of the Driver Station: safety. If you manage to modify it to ignore the "disable" or "emergency stop" commands from the field control system, you've set the stage for an out-of-control robot rampage.
Unread 12-01-2009, 23:36
Mr-Shutter's Avatar
Audiophile
AKA: David
Rookie Year: 2007
yes yes yes, but think of all the fun you will have!
I'm guessing we can use system commands in our c++ programming then tough?
I guess after the compilation i can re-flash it with my own image and then have some fun :3.
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
Securing the Driver Station? Madison FRC Control System 16 16-12-2008 03:05
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
