Go to Post For example an iron block is very simple and very robust. Strap a control system on it and it will meet the requirements of being a FIRST robot. However, it sure doesn't do very much, nor is it innovative. - sanddrag [more]
Unread 12-01-2009, 17:31
lingomaniac88 lingomaniac88 is offline
FRC #1554
Rookie Year: 2007
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
Importing WPILib?
After looking at some of the threads here, I learned that I can't download the WPILib from SourceForge now. I downloaded the WPILib from http://first.wpi.edu/FRC/frcupdates.html, so I was thinking of importing all the necessary files into a project and using that for developing my robot code. Has anyone else done this successfully? Or is there a better way to do this?
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
importing COM objects vectra17 Programming 1 15-02-2008 07:59
Importing Teams in FTC Scorekeeper Shof General Forum 4 13-02-2008 07:50
help importing from inventor JeffO 3D Animation and Competition 3 20-12-2004 13:47
C++/VB Direct3D Mesh Importing Help Adam Shapiro Programming 6 29-01-2003 18:58
Importing Inventor Assemblies into 3dsMAX cyanutopia 3D Animation and Competition 1 25-02-2002 12:22
