Go to Post First of all, please remember that while we often focus on winning the Chairman's Award, that it is the effort to win that matters. No one "loses" RCA... if you've worked your butt off all year in the spirit of the award, then you've already won before you even get to the regional. - dtengineering [more]
Unread 12-01-2009, 22:21
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Rookie Year: 2007
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Gearboxes for shooter?
oh-kay....
so we've been prototyping a shooter mechanism, using a CIM and the kit wheels from last year...only problem, we dont have any (easy) ways of powering it, toughboxes only give us around 300 RPM, so we took out a few gears and got it down to 4:1 wich should give us around 1200 RPM(hopefully)
now ive heard(read) about other people just directly driving the wheel off the cim motor how can this be done?
1200 RPM should be enough right? if not we can use chain reduction(upduction)
so the question is....what other ways are there to do this?
(yes i read the other thread, this is more from a assembely standpoint though)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 12-01-2009, 22:47
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Rookie Year: 2007
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Re: Gearboxes for shooter?
we're using a CIM on a 9:1 Banebots planetary. Gives us more torque so the wheel doesn't slow down as much as each ball goes through, and still keeps a hefty RPM on the wheel. Also theres the added benefit of really easy direct mounting since the output shaft is a simple 1/2" OD with a 1/8" keyway. Though we are actually going to use a sprocket combination with it to give the possibility of high torque or high RPM based on what our testing shows.
Unread 12-01-2009, 22:56
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
using a hub?
we have the 12:1 BB's but there kinda slow...
Adam Spears
Unread 12-01-2009, 22:59
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Well, the CIM is actually 4300 rpm
http://www2.usfirst.org/2005comp/Specs/CIM.pdf
I'll assume it hasn't changed since 2005
-- Marshal Horn
Unread 12-01-2009, 23:03
rbrown1 rbrown1 is offline
AKA: Rex Brown
FRC #1730 (Team Driven)
rbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant futurerbrown1 has a brilliant future
You can use a shaft on your wheel and a love joy shaft coupler to connect the two shafts.
Unread 12-01-2009, 23:05
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You might consider using only a belt or chain drive, with a reduction ratio of about half the inch diameter of the wheel. ie. 4:1 for an 8" wheel. With the smaller pulley/sprocket on the motor.
Unread 13-01-2009, 21:31
gorrilla's Avatar
AKA: adam spears
Rookie Year: 2007
thats what we did,
one CIM in a toughbox chained to a sprocket(which is bolted) on a 5/8 shaft.
(using two kit wheels from last year, bolted together(not attached to the shaft at all!!! just the compressin of the wheel-bolts and the plastic hubs are enough to hold it on the shaft nicely)
works pretty well, we are getting around 6ft maximum distance, and at 4ft were getting around 80% accuracy
Adam Spears
Unread 13-01-2009, 21:40
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
Team Role: Leadership
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
A couple of years ago, for Aim High, we decided to just direct drive the wheels with a connector we designed to fit with the keyed shaft. It took some time to design the right parts but it worked well. It was a last minute addition and due to weight we didn't get to use it, but it worked really well. It's just another option.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 14-01-2009, 02:59
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Originally Posted by gorrilla View Post
thats what we did,
Not sure why you would go through a toughbox?
A direct drive from the 2.5" CIM is more than enough speed to get you more than your 6ft max distance with a 6" wheel.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 14-01-2009, 09:54
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
But if your system needs alot of torque a direct drive CIM may not cut it. Attached directly to a 6" wheel I think it would get you much further (20 feet or more), but if you don't want that distance it helps to gear down and limit your distance but be able to fire balls at an even higher rate.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 14-01-2009, 10:05
MrForbes's Avatar
AKA: Jim
Be sure to read the other related thread
http://www.chiefdelphi.com/forums/sh...threadid=71854
Seems that it's possible to make it work with a direct drive CIM, or with chain/gear reduction.
We're planning to build ours with chain reduction, that can be changed to see what works best.
Unread 14-01-2009, 10:24
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Might want to check out Joe's "Nothing but Dewalts" White paper.
The combination of 3:1, 4:1 and 12:1 with servo shifting on the fly, plus the fact they are a fraction of the weight of the Banebots gearboxes make them a lovely addition to any FRC robot. We ran them last year on our drivetrain and were very impressed. You might even see 4 or 5 of them on our 2009 bot
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 14-01-2009, 11:44
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Some considerations that haven't been mentioned:
  • The tip velocity of the shooter wheel is proportional to the wheel diameter. Larger wheel = faster tip velocity = further shot. You can't ask us for RPM without telling us your wheel diameter.
  • 2 Wheels (top & bottom or right & left) will result in the ball leaving the shooter at double the velocity. (With a 1-wheel system the ball is "rolled out" of the shooter, with 2-wheels the ball is "tossed".)
  • Recharge time will depend on your gear ratio. Luckily the CIM has tons of power, so you should be fine if you're gear ratios are somewhat reasonable.
  • System rotational inertia will also affect recharge time and will affect how much speed the wheel loses during a shot. More inertia = less speed loss = more repeatable shot. How much mass do you have spinning? Hint: If you don't want a heavy system but still want a high rotational inertia put the mass as far out as possible (make the wheel heavy at the edge.)
  • How far do you want to shoot? If you're looking for a short range shooter you might find that a lower RPM wheel will be more accurate in the ranges you want, and will result in a faster fire rate (the wheel don't need to slow down).
  • We found that the compression on the ball will affect the shot distance. Experiment. We like 1.75" of compression. Your mileage may vary.
  • What type of shot do you want to make? A fast ball? A lob shot? This will greatly determine how fast you need to launch the ball. What angle will your shooter be at?
Overall... the secret is PROTOTYPING! Design is an iterative process. Do some basic design in your head. Build it. Test it. Improve it. Repeat until satisfied. This is the secret to the entire 2009 game. The teams who do really well this year will be the ones who experiment a lot.
Good Luck!
-John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 14-01-2009, 15:58
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Originally Posted by JVN View Post
Some considerations that haven't been mentioned: (...) The teams who do really well this year will be the ones who experiment a lot.
Aw, John, you just cut-and-pasted this from the Aim High game, right?
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
  #15   Spotlight this post!
Unread 14-01-2009, 16:01
MrForbes's Avatar
AKA: Jim
I think he could have cut and pasted from any year to get the experiment quote
motor for ball Shooter? excel2474 Motors 42 15-01-2009 09:48
which gearboxes can we use for this year? mahmosh Kit & Additional Hardware 2 09-01-2009 19:52
Which pinions for FP motors and BaneBots 42 mm gearboxes? Madison Technical Discussion 3 23-01-2007 20:04
Speed Sensor for Ball Shooter Justin Stiltner Electrical 15 28-01-2006 14:40
