Go to Post Our opponents didn't know where our robot was going and neither did we! - ReapersRule [more]
Unread 13-01-2009, 02:44
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Hooking LED to DS
Hey i wanted to check with anyone have you hook up led to the diver station. And if so how i dont want to short it. so i want to check what size resistors if any ect.
Unread 13-01-2009, 08:21
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Hooking LED to DS
To connect an LED to the Driver Station digital output, connect one end of a 100 - 200 ohm resistor to the upper digital output pin, then connect the other end of this resistor to the anode on an LED, and connect the cathode of the LED top the lower pin (ground) on the driver station.
The sketch below shows a schematic for this.
UPPER PIN ----/\/\/\/\-----|>|---- LOWER PIN
....................150 ohm......LED
A typical red LED has a forward voltage of about 2.2 volts, and gives good brightness with ~ 20 ma of current through it. This means that the resistor needs to drop 5 - 2.2 volts, or 2.8 volts. Using Ohms law (R= E/I) gives a resistor value of 2.8/.02 = 140 ohms. 150 ohms is a standard value, and will work well.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 13-01-2009, 09:12
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
Team Role: Leadership
Rookie Year: 2007
seanl will become famous soon enoughseanl will become famous soon enough
also you could make a LED in the dashboard VI instead of hard wiring it.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 14-01-2009, 14:49
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Keep in mind that different LED's operate at different current settings. The digital output signal pin produces 5V of power when turned "on". Find an appropriate 5V LED (most of them are 5V) and then do some math to ensure you get the proper resistor to place inline with the LED, based on the current requirements for the LED. Many places you can order LED's from will have them available with the matching resistor as well.
Hooking up a custom OI panel Cullen Team 372 Control System 3 12-02-2008 17:26
Hooking up a backup battery neoshaakti Control System 7 26-01-2008 22:09
hooking up potentiometers chippermonky Programming 1 05-02-2007 20:04
Hooking up 2 Servos kutty18 Programming 7 04-02-2005 09:26
hooking up sensors to controller? Oakridege_665 Technical Discussion 5 21-01-2002 14:55
