Go to Post IYou might get it all changed over and discover your robot has trouble moving from a dead stop, can no longer turn without playing morse code on the breakers... - KenWittlief [more]
Unread 13-01-2009, 09:18
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
Using the analog sensor .vi's
So after 6 hours of troubleshooting, my programming team and I have finally found out why the analog sensors vi's weren't working in labview. First of all, when the "open" vi asks for a channel and slot input, instead of just putting in 1, 2, etc... we needed to put in "slot one" and "AI 1" for slot one channel one. Secondly, since we didn't have any analog output devices we decided we would just use channel 8 in slot one, which should have given us a modified battery voltage response. The only problem is that it seems that there is a conflict with this situation. I believe that since the DS is also trying to read the battery voltage from this channel, and so there is some sort of a programming conflict and the battery voltage won't show up in labview. I don't know if there is any work around to this problem, I just thought I would let other teams know in case there were in the same situation as ours.
Relax! It's only ones and zeros!
Using Analog Inputs as Digital (on the OI) Guy Davidson Control System 16 10-03-2008 17:17
pic: Robostang's Analog Sensor test software Robostang 548 Extra Discussion 11 23-12-2007 09:55
Using gyro.c with other analog sensors no go Astronouth7303 Programming 17 03-01-2006 21:04
Using gyro with other analog sensors...again demerski Programming 0 19-02-2005 08:23
Using and Coding an ultrasonic sensor Jaine Perotti General Forum 14 06-08-2004 14:13
