Go to Post Analyze, adjust, anticipate. Don't panic. - PayneTrain [more]
Unread 13-01-2009, 20:23
lamoreaux2198 lamoreaux2198 is offline
FRC #2198
lamoreaux2198 is an unknown quantity at this point
Axis Camera w/ Labview problem
Our team has already installed the camera online and have received the ip address and domain name. However, when we try to set it up with Labview an error message pops up saying the ip does not match.
We have followed the step-by-step manual guide and we are sure that there is no problem with the camera but we can not connect to Labview.
If you suspect it to be an IP problem can you explain to us in steps on how to connect it to Labview. By the way our team number is 2198.
We greatly appreciate your help
Thank you
Unread 13-01-2009, 20:55
David Doerr's Avatar
David Doerr David Doerr is offline
FRC #4478 (Materia Oscura)
David Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud ofDavid Doerr has much to be proud of
Re: Axis Camera w/ Labview problem
It sounds like you do have an IP address problem. The camera doesn't care what your team number is, but likes to have a static IP address of 192.168.0.90.
There are several ways to set the IP address. The easiest is to use the "FRC Axis Camera Tool" that comes with your software installation. First connect your camera directly to your PC with the orange crossover cable that comes in your KOP. Then double-click the "FRC Axis Camera Tool". Wait a few seconds, and if the everything works a small window will pop up on your PC that says "Successfully completed".
I'm hoping that will fix your camera problem.
Unread 14-01-2009, 04:38
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
First and a half, make sure that your firewall is disabled.
Axis Camera Programming in Labview Striker_27 NI LabVIEW 10 09-01-2009 19:19
Axis cam problem keehun Programming 8 07-01-2009 11:32
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Program Axis Camera in c++ excel2474 Programming 5 22-12-2008 17:14
axis camera - problem s0crates FRC Control System 11 16-12-2008 09:34
