Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 14-01-2009, 13:04
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Shooter vs Dumper Trade Study
So what are the pros and cons of either design and why is one better than the other?
I'll start:
To me, shooting assumes you can't get to a trailer to score and you need to score from a distance (I guess because of the limited drive capabilities). But having 3 trailers to score in seems like there will always be one nearby. Also shooting seems like it will take too long and have more chances for jamming. Also in Aim High hitting a stationary target was hard enough, so how do you hit a smaller moving target with non-uniform objects (broken balls) consistently?
A dumper assumes you can get up close to a trailer, scores all at once and less mechanisms to jam. Doesn't care about ball shape.
I realize there's hybrids but ultimately it seems you still fall into one of these categories. Yes/No?
www.179swampthing.org
Unread 14-01-2009, 13:13
Kellen Hill's Avatar
Kellen Hill Kellen Hill is online now
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Re: Shooter vs Dumper Trade Study
I personally think that effective dumpers will score a majority of the points and dominate the game. Unless you have a shooter like Wildstang in 2006 of course.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 14-01-2009, 13:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
A short range turreted shooter will allow you to score when you are close to the goal, and from either side of your robot. A dumper probably requires you to be lined up and right next to the goal. Since the goals will probably be driving away from you, using the finest evasive maneuvering techniques, you'd have to be really lucky to be able to dump a load of balls in a functioning robot's trailer.
Unread 14-01-2009, 13:35
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
There are times during game play where a dump is very viable..and easy.
When another team is unloading into the airlock, the trailer is stationary.
When another team is at the outpost getting the empty cell, the trailer is stationary.
When another team is pushed up against a wall by two robots, the trailer is stationary.
A dumping bot of sorts only needs to get to a trailer goal once or twice in a match to make a big difference.
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 14-01-2009, 13:38
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Team Role: Teacher
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
[quote=Swampdude;800801]So what are the pros and cons of either design and why is one better than the other?QUOTE]
So why not build something that does both effectively?
Unread 14-01-2009, 13:44
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
How about a shooting dumper??
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 14-01-2009, 13:55
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is online now
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
How about a turreted shooting dumper?
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 14-01-2009, 14:03
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Bingo.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 14-01-2009, 13:50
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Advantage to a shooter is that presumably, it can act as a dumper simply by slowing the spinning of its power mechanism (wheels, etc).
Based on our tests so far, it appears that tracking and auto-targeting opponent's trailers' is possible:
-We successfully wrote code that can distinguish an opponent's trailer
-The same code can give you distance and heading information within a few % points of the true value.
-By tracking the change in distance and heading, you can determine both the position and velocity of an opposing team's trailer, and thus lead it by an appropriate amount.
But:
-The enemy trailer will pretty much never be moving at a constant velocity
-There appears to be fairly substantial slowdowns in the camera code. It's not really real-time, more like 500ms-behind-real-time. We don't know how much this can be fixed, that'll be tonight's meeting's topic.
-The balls are irregular, and will become even more irregular as regionals proceed. Thus, muzzle velocities will be unpredictable.
-'Camping' and shooting will not be effective: you'll be a sitting duck for dumpers. Handling the accelerations that your robot is undergoing as well as the accelerations of your target will make your shooting much less accurate
When we were doing our original analysis, we essentially decided that shooters will have more opportunities to score, but will convert fewer of those opportunities into actual points.
Unread 14-01-2009, 13:54
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
There is a hybrid option that really doesn't fall into these two categories though. A shooter doesn't have to use a turret and camera (and may not want to since it restricts you to one ball at a time), but could instead pursue a similar strategy to a dumper of getting close to an opponent's goal and unloading a large amount of balls into it. Being a shooter allows you to power the balls (instead of relying on a gravity dump) and gives you a few foot range rather than requiring your robot to be right next to the opponent.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 14-01-2009, 14:08
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Originally Posted by Bongle View Post
But:
The low friction and thus low acceleration minimizes the effect of these problems.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 14-01-2009, 14:34
Bongle's Avatar
If your shooter has a moderate speed (8ft/s), then a robot just 10ft away could accelerate hard enough to be 1.5ft away from where you expected it to be (if you assume constant velocity). If you add in the inevitable imprecision of an orbit-ball shooter, the amount of balls you'd get in would be low.
A powered dumper seems to be the way to go.
Unread 21-01-2009, 02:10
AKA: Josh Hecht
By similar arguments, a moving robot further than 1-2 feet away will, at the least, be a challenge to reach and dump into, particularly for long enough to dump all the stored orbit balls. I don't know the radius of the goal offhand. Isn't the radius about 1.5ft? If the error due to acceleration is just that, then the only real concern is the precision of a shooter. I can't comment on that
Also, 10 feet really isn't that close. Robots can easily get within 5 feet of eachother, I just envision trouble getting closer (and staying there)
There's no right answer, and teams will get both ways working, but I feel confident saying this just from the nature of this year's driving: if you can build a device that aims independently of your robot and propels the balls (at least slightly), you will have a much easier time getting balls in the goal. There are still other tradeoffs, of course.
Team 694
Unread 14-01-2009, 13:51
David Guzman's Avatar
David Guzman David Guzman is online now
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
In my opinion a shooter robot will be more reliable than a dumper robot.
While a dumper robot can score massive points when given the opportunity, it is relying on the mistakes from the opposing alliance to be able to make a dump.
A robot with a shooter will need to use the camera to track the trailers to be a threat. If the camera is used successfully and the shooter is geared correctly so it can score a lot of balls very quickly, then it will dominate.
I think the combination of a good shooter and a good dumper in an alliance will be very powerful.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
  #15   Spotlight this post!
Mr B's Avatar
Mr B Mr B is offline
AKA: Andy Bradley
FRC #0233 (The Pink Team)
Rookie Year: 1998
Mr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to allMr B is a name known to all
It seems to me that the biggest constraint of dumping balls into a goal is the size limit of the robot <R11>. Without being able to exceed the perimeter, dumpers would have to be right next to a goal and be relatively unmolested to score a high percentage of balls. Still, a team that figures out a way to dump a load reliably and fast would be a force.
Defensive/dumper hall of fame Cody Carey Robot Showcase 80 11-03-2007 18:44
Poll: Dumper effectiveness at Championship The Lucas Championship Event 3 23-04-2006 00:33
pic: new dumper supersy77 Robot Showcase 2 11-04-2005 15:17
Ball Dumper Plans JDRobotics General Forum 6 22-01-2004 17:38
Anthropology Study Redhead Jokes General Forum 0 22-01-2004 13:56
